[♛ FreemeGB] ASTROLUX FT03 XHP50.2 (3V) 4300lm 735m 26650/ 21700/ 18650 Flashlight - SHIPPED!
https://streamja.com/embed/Jl4l
only 50.2 version available now, the video shows the comparison between sst40 and xhp50.2 led
Available? Where?
If you say available NOW, will there be a 70.2 version in the future?
They are still in the warehouse in China waiting to be shipped overseas.
70.2 version was cancelled as far as I know
That sst-40 test looks accurate enough, 4250 for the XHP50.2 is very close to what i’d expect a xhp70.2 to do in that form factor unless they go with an expensive driver but with probably double the CD.
Gonna heat up way too fast with an XHP70.2 too.
plus, 3v xhp50.2 is probably going to keep the cost WAY down.
Seems like the springs will be pushed to the limit, especially since this is a 26650 light.
By pushed, I meant in terms of current to support.
No. 26650
50.2 is still going to need a boost driver or no?
No, it’s a 3V XHP50.2.
It’s going to use the same FET+1 driver.
Nice. Should be the same NarsilM firmware as the SST version then.
I am interested in the 50.2. NW of course. CW if that’s the only option. May even grab 2.
I̶n̶t̶e̶r̶e̶s̶t̶e̶d̶ ̶i̶n̶ ̶N̶W̶.̶
Wrong thread, didn’t realise this was for the XHP50.2 version.
Do you know the specific tint they plan to use on the NW? I am hoping 3A tint
Interested for 2 nw
Interested, possibly for 3
The FT03 with the 3v 50.2 is very nice….
I would be in for a few of them…not for myself…friends…
interested in 1 or 2 NW.
Keen!
In for one FT03 XHP50.2.
Let’s see if I understand correctly, the XHP50.2 may have around similar lumens as the SST40, but will have a bit more floody (but smoother) beam pattern than the SST40. Also XHP50.2 may (or may not) have a nicer tint than the SST40?
SST40 at low brightness levels will look a bit yellow/greenish.
XHP50.2 beam tends to have a hotspot that’s cooler and a corona/spill area that’s somewhat warmer.
