Economy shipping (Registered, SAL) now available for non-ASEAN countries for $5.25. This shipping methods takes 3-7 weeks on average to arrive (not including customs clearance).
“Bare-Fare” Shipping (SAL, non-registered, untracked) is also available (3-7 weeks not counting customs clearance) at your own risk for $2.5.
If you wish your item to be shipped by one of these two methods, please tell me in the PM. Otherwise, I will assume the shipping method “Priority” by default.
Depends on how you want to power this. If you want to just power it off the mains, you just look around for the “100w led driver”. There are plenty of them over the Amazon/eBay/Aliexpress. Here’s the example (this isn’t the best quality available, but you could also search around). You might also want to pay attention to the efficiency and power factor of the drivers if electricity bill is a concern.
On the other hand, if you want to go with a more DIY-ish route, or you want to power this off a battery, You could also buy a Buck/Boost converter (preferably with Constant Current feature) and hook it up to the Battery/DC power source. DIY perks made a video on how to wire it up. (It’s a different COBs but it’s functionally the same as this one).
I’m loving the CRI data, but the 5700k color is a bit intense for home use, and a bit yellow for my photo lighting. I would love to play with one though…. hmmm
How about something like this? This thing from Aliexpress looks remotely like a TIR, but I’m not sure if it’s qualifies as one…
By the way, do you want more flood or more throw?
Thanks for looking. That lens is plastic and says up to 50w. I think it may have issues at 100w. How big is the emitter area on yours? I found some glass ones for 26mm LEDs.
As far as the lens is concerned, if you are worried that you might burn out the lens with 100w cobs (and you are fine with getting 50w of light output instead of 100w), you can underpower these COBs by pairing them with a 50w driver (or drive them with half the current).
Not yet, at least not in the same form factor. The major reason is that by simply sourcing 100w (the most powerful) variant, it gives buyer choices to run it at lower power settings without having to deal with too many product lineups (which I cannot financially deal with as of now). Also, once overheads (such as shipping costs) are taken into the equation, the lesser variants don’t get that much cheaper.
Aside from some tint shifts (that is can potentially be a negative thing), underdriving a more powerful LEDs will result in better efficiency and longer lifespan. As far as voltages are concerned, all variants in this form factor (except the AC ones) are to be run at the same voltage. All you need to do is to pair it with a less powerful drivers or just feed it with less current.
