Review: Convoy C8+ Sand/Desert Tan
16 posts / 0 new
stephenk
stephenk's picture
Last seen: 1 month 3 days ago
The Convoy C8 is a classic budget thrower flashlight that has been around for many years in various iterations. With many other manufacturers selling lights identical in appearance, it was time for Convoy to introduce a new look C8 – introducing the Convoy C8+.
Disclaimer
The Convoy C8+ was send for an honest review by Banggood. Product Link.
$20.99 with code:02c657
Construction
The Convoy C8+ arrived wrapped in bubble wrap, inside a plain white cardboard box. The only included accessory was a lanyard.
The Convoy C8+ has a similar overall profile to the C8 with a larger head than the battery tube to accommodate the smooth reflector and Cree XP-L HI LED emitter, however the addition of cooling fins on the head and tail provides a fresh new look. The fins are better for preventing roll than the older C8. The knurling on the tube is much more grippy than the C8. The Convoy logo is now below the head, rather than being along the battery tube. The C8+ is currently available in Sand / Desert Tan colour.
C8 on left, C8+ on right
The head and tail cap both unscrew. The tail cap is anodised, and slight turn mechanically locks out the light for safety. The threads are identical to the C8, and thus the C8+ and C8 can lego to provide some interesting looks (as per the photo). The battery tube in the C8+ is bored wider than in my older C8 (clear anodisation/silver) which allows obese protected batteries such as the Klarus 3600mAh 18650 to fit (just). There are springs at both end of the battery tube which allows both flat top and button top 18650s to be used – take note Nitecore Wink
There is no internal USB charging which is expected at this price point, but may deter some of the consumer market.
Lego C8/C8+
User Interface
The C8+ firmware (known as “Biscotti”) is massive improvement over the previous 3/5 mode user interface on most of the older C8 models which had a few quirks related to memory mode. The 12 mode group options and reverse clicky switch should suit most user requirements, other than those who require forward clickies for momentary output. Options included or excluded from some mode groups include moonlight, strobe, bike flashing, SOS, and battery check. The mode groups are as follows:
1 0.1%, 1%, 10%, 35%, 100%, strobe, biking, battery-check
2 0.1%, 1%, 10%, 35%, 100%
3 100%, 35%, 10%, 1%, 0.1%
4 1%, 20%, 100%, strobe, biking, battery-check, SOS
5 1%, 20%, 100%
6 100%, 20%, 1%
7 0.1%, 1%, 10%, 50%, strobe, biking, battery-check, SOS
8 0.1%, 1%, 10%, 50%
9 50%, 10%, 1%, 0.1%
10 1%, 10%, 35%, 100%
11 100%, 20%, strobe
12 100% only
Changing mode groups and turning memory on/off is fairly easy process, starting with 10 taps to enter configuration mode. I currently have mine set on mode group 2 – 0.1%, 1%, 10%, 35%, 100% with memory on. To advanced to the next mode requires a tap, rather than a full click. Memory mode (when on) works perfectly.
I think Biscotti is a great user interface – very programmable, but also very easy to use. The C8+ has a two frequency strobe. As a light painting photographer I would much prefer a single frequency strobe with 50/50 on/off time. Momentary functionality is also unavailable, but that would require an additional switch or an e-switch, and thus a new design.
Biscotti includes low voltage protection. When the cells are nearly discharged output steps down to moonlight output, and the light continues to run with moonlight output for a few hours. This means that user won’t be suddenly left in the dark. Eventually the low voltage protection will kick in. The cell used for testing was at a resting voltage of 2.9V after the low voltage protection kicked in. The C8+ can also be locked out by slightly unscrewing the tail cap threads.
Heat at 100% power is managed quite well for such a small light. I manually stepped down after 8 minutes (in 16C ambient heat and no wind) as the head was getting too hot for my liking (I’m quite cautious). I did not notice any significant improvement in heat handling compared to the clear anodised C8 (which also has a DTP board) despite the more visible cooling fins. In cooler ambient conditions, the C8 should be able to run the light on high for considerably longer. Heat is not an issue at 50% or lower modes.
Beam and Output
The Convoy C8+ is available with V2-1A, U6-3A, U6-4C, and U4-7A Cree XP-L HI emitter options covering cool, neutral, and warm white. I really like that Convoy have a good range of colour temperatures. Output with a 7A warm white emitter was tested to be approximately 900 lumens at 30 seconds (with freshly charge Sanyo NCR18650GA cells) based on a ceiling bounce test. Peak beam intensity is estimated to be approximately 60k cd. The cooler white versions will have slightly more output, though there is visually not much difference between 7A and 1A in terms of brightness. Cooler white beams are more visible mid-air. There is no difference in output between the more recent clear anodised C8 and C8+.
The beam is typical for a thrower, with a small intense hotspot, and less bright spill beam. The throw certainly has a “wow” factor, and provides useful illumination well beyond 200m, and out performs most zoomy lights on zoom. Due to the use of 7135 chips, the output declines slowly as the battery voltage drops. There is no automatic step-down, which means the light can be run at maximum output until it needs to be stepped down manually due to heat. I like this lack of automatic step-down, but is does require the user to be responsible.
1A C8 Left, 7A C8+ Right
The CRI appeares to be in the typical 70+CRI range. PWM is fast enough to not be detectable in any mode when videoing.
A year of so ago the Convoy C8 was almost class leading in terms of throw. However, in the last year, other budget to mid-market products have come onto the market that out perform the C8 in terms of lumens and throw. Whilst not everyone wants a trouser burning hotrod flashlight, and the C8+ still has a “wow” factor, I would like to see Convoy implement a higher output version with step-down to keep up with market trends.
Conclusion
Things I like:
- Fresh new look
- Simple, but programmable user interface
- No automatic step-down (but requires a responsible user)
- Choice of colour temperatures/tints
- Now fits larger protected 18650s
- Fits flat and button top, protected and unprotected 18650s
- Better anti-roll than original C8
- Good value for money
Things I didn’t like
- Maximum output lacking behind peers
- Two frequency strobe
- No momentary switch
The Convoy C8+ gives the classic C8 a fresh new look. The great user interface, choice of tints/colour temperatures, good heat handling, and great value for money make the C8+ an excellent option for a useful throwy light. It is however no longer market leading in terms of throw and output for its class of light.
1A C8 Left, 7A C8+ Right; f/5, 4secs, ISO400.
Edited by: stephenk on 08/03/2018 - 06:44
Jack Kellar
Jack Kellar's picture
Last seen: 13 hours 19 min ago
I’m perfectly okay well with Convoy not competing for the spearhead of the flashlight stat war. Let the expensive premium brands get into that bite fight. And since light painting is so niche, the two-tone strobe doesn’t bother me – heck, the light painters I know are tech-savvy enough to reflash their drivers anyway, and there’s always the 3/5 option.
Still, with the same beam profile and same steel under the hood, I see little reason to go for this instead of swapping the driver of my C8 for the moment. When I have the disposable income to get this cool new model, it’s a gofer, tho… After I get a long-awaited S2+ Glasses
MascaratumB
MascaratumB's picture
Last seen: 29 min 47 sec ago
Cool photo Cool
Thanks for the review Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
Tangra
Last seen: 1 month 1 week ago
I order my C8+ to Simon with momentary on switch and he put it. It works fine and still flashlight can stay in candel position.
neo71665
neo71665's picture
I know a lot of guys don’t like it but I’d like to see a metal switch like the s2+ has.
Still didn’t stop me from ordering one.
MascaratumB
Well, not the same, but check this one: https://www.aliexpress.com/item/Free-Shipping-CountryMan-CREE-XPL-LED-bead-Flashlight-for-Bright-bike-camping-light-lamp-home-climbing/1000004788444.html
Thumbs Up
OL Contest 2019
GIVEAWAY: 1 / 2
MRsDNF
MRsDNF's picture
Last seen: 15 hours 51 min ago
Thanks for the review Stephen. TK’s Biscotti is one of my favourites.
It may lag in output compared to some but there will always be a place for a responsible light for the majority in our community. Smile
chadvone
chadvone's picture
Last seen: 3 days 20 hours ago
[quote=MascaratumB]Cool photo Cool
One of the best photos I have seen in a while.
stephenk
stephenk's picture
chadvone][quote=MascaratumB wrote:
Cool photo Cool
Thanks, much appreciated!
Hugh Johnson
Hugh Johnson's picture
Last seen: 2 weeks 20 hours ago
Nice review. Thank you.
Rjtorres23
Last seen: 12 months 4 days ago
I have an issue with my new C8+. It's stuck on low mode and won't allow me to go into programming. I've successfully programmed it less than ten times. I've used different batteries to see if that was the problem. Any resolve?
Russell Torr3S
RelakS
Last seen: 2 weeks 15 hours ago
Yesterday I have played around with this. I was able to clearly distinguish a white statue from the rocky/grassy hill behind it from around 200m. From 100m I were able to see its surroundings also.
QMT93
Hi, can you tell me who Simon is in your reply? Is this his website: https://simonflashlights.net/?
BlueSwordM
BlueSwordM's picture
Last seen: 10 hours 26 min ago
QMT93
Ah,thank you!
If I choose mode 12, “100% only”, which is 1,100 lumens, how long can it last and how hot would it get?
Swabs
Swabs's picture
Last seen: 7 hours 26 min ago
My Convoy C8+ with luminus sst40 6500K Four Step arrived today from AliExpress. I’m using a Sofirn 18650 3000mAh battery until the Samsung 35E 18650 8A Flat Top 3500mAh Battery arrives from Liion next week.
I love this thrower, wow! I am so glad I ventured out and bought a Convoy. And, I am glad I bought this particular one, $23 delivered is incredible. It throws for days, compared to my other nice budget lights.
My Fenix PD36R has the Luminus sst40, too, but the Convoy just kicks it over as far as a dedicated hot spot distance thrower. For 2K lumens, color me impressed.
My Future's So Bright...well, my flashlights are anyways.
strobe me, strobe me. STROBE! STROBE! strobe me, strobe me. STROBE! STROBE!
