[M4D deal ACTIVE] LiitoKala Lii-500S groupbuy
:+1: …… Ouch, that sux. :frowning:
On that topic, for those who already own Lii-500 and are now getting the Lii-500S, battery direction has been reversed. But at least the charger is supposed to have reverse insertion protection.
I how to never need the protection again haha
Thanks, I ordered one
It’s good they put the direction back to “normal” on their new version.
However, I’ve accidentally put cell in backwards in the old Lii-500, and it just refused to charge. It didn’t fry anything.
Thank you for the deal, I just placed my order!
Can it load longer cells than lii-500?
I handles 21700 supposedly.
Not that I needed another charger, I ordered one because I’m a boy who loves his toys.
Signed, Beaver Cleaver
/\:sunglasses:
I’m wondering about the 3 operating modes: “CHARGE, DISCHARGE and TEST modes”.
I don’t suppose we’ll get an answer unless someone finally gets the unit to test.
To recap, the old Lii-500 Engr has Charge, Fast Test and Nor Test.
“Charge” does what it says: charge to Full.
“Fast Test” will discharge the battery to Empty (around 2.80v for the Lii-500), then will start charging to Full, measuring the Charged Capacity along the way.
“Nor Test” will first charge the battery to Full, then will Discharge the battery to Empty (around 2.8v), and report the Discharged Capacity; as a final step, the Lii-500 will also fully charge the battery after it has fully discharged the battery (the user can remove the battery any time after the Discharged Capacity is shown, if he doesn’t need the battery charged to Full,)
For the Lii-500S:
“Charge” likely works similarly: charge to Full (4.20v for Li-Ion)
“Discharge” = I wonder what this means — is it another name for the previous “Fast Test”, or can it possibly work like the “Discharge” function of the Opus BT-C3100? (ie. discharge battery from whatever state (can be in “not Full” state, at least for the Opus BT-C3100) and then display the Discharged Capacity?
“Test” = I would presume this works the same as the previous “NOR Test” = first charge to Full, then Discharge to a pre-set Empty voltage (probably around 2.8v), report the measured capacity, then Charge back up to Full.
I just got a email from banggood that the charger is out of stock.
Received my shipping notice today. Expected delivery in about two weeks.
It was not in stock when I ordered mine. It was estimated to be back in stock around 18 June.
Mine still says “processing”
Mine too. If I click the “blue Processing” it takes me to the order. It says shipment is estimated to be 18 June. We shall see…. :wink:
The coupon doesn’t seem to work anymore. It says “This coupon is not available for limited offer products”
Promotion Sale From June 10 to June 16. - that disables my discount
Ordered early on in deal, but out of stock email came today :frowning:
Did they cancel your order? Last time I got out of an out stock message they offered the choice for refund or wait for restock
