LiitoKala lii-500S - New HIT or ...?
77 posts / 0 new
Mishanchik
Mishanchik's picture
Last seen: 34 min 5 sec ago
lii-500s
lii500s
Specification
Input voltage: DC 12V/3.0A
Output voltage:DC 4.2V / DC 1.48V
Output current
Lithium battery charging current: 500mA*4 /700mA*4/1000mA *4 2000mA *2
NiMH battery charging current: 500mA*4/700mA*4 /1000mA*4
Rechargeable battery specifications: 26650,21700,18650,18350, 20650,14500, AA, AAA, etc.
Discharge current: 250mA / 500mA
USB output: 5V—-1000mA
Termination method: intelligent voltage monitoring
Dimensions: 162mm (length) * 100mm (width) * 36mm (height).
*Note: The results of the Lii-500S charger test are for reference only and do not make any professional proof. *
Features
1. New touch control function;
2. Four optional charging currents: 500mA*4/700mA*4/1000mA *4/2000mA*2;
3. Two discharge currents: 250mA*4/500mA*4;
4. It can charge different batteries of different specifications (18650/26650……/AA/AAA);
5. This product uses a separate LCD display, charge and discharge mode (MODE). Voltage (V). Current (mA). Time (h). Capacity (mAh) parameters, at a glance;
6. CHARGE, DISCHARGE and TEST modes can work simultaneously; independently set charge/discharge capacity detection/normal capacity detection function;
7. A variety of protection functions: overcharge and over discharge, short circuit, temperature, 0V voltage activation function, (-ΔV & 0ΔV), 1.65V-2.2V non-charging function, intelligent identification of bad battery and reverse battery detection protection;
8. With standard 5V/1000 mA USB output function (only valid when AC power is connected)
Edited by: Mishanchik on 06/09/2019 - 09:47
Henk4U2
Henk4U2's picture
Last seen: 2 hours 12 min ago
And?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Mishanchik
Conclusions everyone makes himself. The device is new, and there are no reviews yet.
NorthernHarrier
NorthernHarrier's picture
Last seen: 3 weeks 10 hours ago
I ordered one using a nice discount, as it has some obvious advantages over my aging Xtar VC4 and it was not a big investment. I would prefer if Liitokala had kept the 300mA charging current option of the previous model, but it is not a big problem for me, with my smallest capacity cells being 16340’s and AAA’s. I will probably use my Xtar SV2 Rocket charger, with its 250mA charging current option, to charge my 16340’s, but I don’t see any major cell-life shortening consequences from using the 500mA in this charger on those cells (still less than 0.8C).
As for charging NiMH cells, I do worry somewhat about the voltage monitoring charge termination method employed, as in other chargers that can lead to cells not being charged to their full capacity – but I will try them in the 500S and see how it works. I hope the engineers at Liitokala have developed firmware for this charger that can do a decent job of filling NiMH cells to capacity.
Mishanchik
We will be waiting for you to review this charger.
teacher
teacher's picture
Last seen: 2 weeks 2 days ago
Yeah, I ordered one too. Looking forward to getting it to check it out & see how it stacks up against the old tried & true Lii 500.
atbglenn
atbglenn's picture
I ordered one as well. I’m still waiting for it to ship.
Boycott Nike
Mishanchik
Guys, we are waiting for your reviews! It is a pity that I do not see support HiLV (4.35) and LiFePO4… Why does the Liitokala chargers in the engineering line (Lii500, Lii-400) not add support for these cells, аnd in the line of cheap chargers (Lii 402, Lii202) there is support. Strange logic.
Nicolaas
Last seen: 3 weeks 4 days ago
Only difference I see with the (in my opinion very good) LII-500 Engineer is . . . . . . new display, new looks. Is all.
Cheers,
Nico
BOMBAY
Last seen: 1 hour 59 min ago
Can it load longer cells than lii-500?
Mishanchik
lii500s21700
I could not find the detailed specification. Judging by this photo, 21700 is supported, but 21700 with protection will no longer fit
TrueRMS
Last seen: 14 hours 10 min ago
Looking forward to receiving mine, my only concern is that i have an original too and dont like that they changed the polarity. I mean I never liked how you put the cells in backwards on the original but stick with it now! Probably gonna mark them with red/green paint or something.
teacher
teacher's picture
Yep, me too. Not sure if you noticed Fred, but it was a Pre-Order. Fulfillment is supposed to be by 18 June. Ward supplied me with that info. I think June told him. Wink
Mishanchik
Where have you found where you can buy on pre-order at an interesting price?
Pete7874
Pete7874's picture
Last seen: 1 hour 27 min ago
http://budgetlightforum.com/node/67412
Pete7874
Pete7874's picture
Cheers,
Nico
- Support for 21700 cells.
- More spacing between slots.
- 2A max charging current.
- no 300 mA charge rate.
Mishanchik
teacher
teacher's picture
Yep, what Pete7874 said ABOVE. . Thumbs Up
Phlogiston
Last seen: 13 hours 6 min ago
Going to wait for reviews, myself. If they’ve sorted the Lii-500 niggle of only charging to 90% on NiMH, then I’m interested Smile
hammerJoe
Last seen: 1 month 1 week ago
What? The 500 only charges Nimh to 90% capacity? I never heard of that. Where can I read more about it?
teacher
teacher's picture
I have not noticed that phenomenon with my Lii500.
Phlogiston
In HKJ’s review:
http://budgetlightforum.com/node/41442
Search for “Charge NiMH”; there’s a bit that says: “The termination look like a voltage termination and without filling the cell completely. Generally it looks like the capacity display is a bit high for NiMH cells.”
Looking at the graphs, it seems to be falling short by about 10%. The charger shows about 1900mAh – 2000mAh, but HKJ’s equipment only shows about 1700 mAh – 1750mAh going into the cell. The effect appears to be consistent across all four slots.
In his conclusion, HKJ again mentions that: “The charger is very good at charging LiIon, but stops a bit early on NiMH.”
I’m wondering whether the person who wrote the charging algorithm forgot to account for the pauses while it’s measuring the cell voltage.
teacher
teacher's picture
Hmmmm…. Thanks for the info Phlogiston. I’ll have to look at/check mine out more closely. Facepalm
RapidLux
RapidLux's picture
Last seen: 12 min 45 sec ago
Phlogiston wrote:
In HKJ’s review:
Now I understand why my Ikea Ladda AA 2450 mAh batteries last considerable shorter in my Logitech Mx Mouse, compared to using disposable batteries. Hope they fixed it with Lii-500S.
Barkuti
Barkuti's picture
Last seen: 12 min 14 sec ago
The Lii-500 uses multiple Ni-MH end of charge detection algorithms, including voltage termination. Modern Ni-MH cells are not overcharge tolerant, thus if the charger decides to use voltage termination for some cells or in some cases I concur with this.
I recently measured the capacity of 11 Turnigy sub-C 4200 cells from a dismantled drill battery pack whose owner left the battery without charge a full day or more after fully depleting it (something which caused one cell to get reversed, die and get shorted). Cells had less than 10 cycles. Each cell was tested 2 times in slots 1 and 4, 22 tests total. Final average capacity was 4189.27mAh. None of these got a voltage termination in any case, for sure.
Saying the Lii-500 undercharges Ni-MH cells is a fallacious generalization. And in any case, what I said above.
Innocent
mattlward
mattlward's picture
Last seen: 1 day 4 hours ago
I am a little disappointed in the #8 “feature”. You can only use USB out if running on a/c power, not able to charge USB devices off of the cells in the charger.
EDC rotation:
FW3A, SST20 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
Emisar D4V2, SST20 4000k
Zebralight SC52w-L2
Zebralight SC62w
Barkuti
Barkuti's picture
The main problem of using external or removable cells to feed a power bank boost circuitry is additional cell contacts and slot resistance burden, causing voltage drop, lesser efficiency and overall making the boost engine's life harder. If slot rails were made tight, high quality and were to remain always clean the idea would make more sense. On top of this lesser drain and/or small cells cannot provide enough power output to make the power bank function work reliably. When you tally up all of this, plus general user's ignorance and easy availability of standard power banks, I can understand why the power bank function is dropped from the charger.
Smile
Innocent
NorthernHarrier
Received my Lii-500S today. I like it a lot, so far. The display is really nice, and it is easy to learn the user interface.
I know it will now be my go-to charger for Li-ions. Time will tell if it also will work well for me in charging NiMH cells. I will be interested in seeing a review by someone who can methodically test the ability of this charger to fill NiMH cells without overcharging them and post the results. I am optimistic, based on the reviews of the previous model, that the 500S will likely be kind to the cells and will not overcharge them.
teacher
teacher's picture
@ NorthernHarrier
1. When did you order yours?
2. Did you get it from Banggood??
Glad you received yours….. Beer
Barkuti
Barkuti's picture
The Lii-500S can also be bought in AliExpress at an even lower price than the current one in Bangbad Banggood, or bundled with a vehicle ashtray plug adapter. With “free” tracked shipping.
Smile
Innocent
teacher
teacher's picture
Smile
I can’t even read it enough to figure out where to change it to English. Facepalm
Thanks anyway Barkuti…. Beer
