M4D M4X deals - Astrolux WP1 and WP2 LEP
I just noticed that the published outputs for the L1 are the same as for the EDC C1, even though the battery in the L1 is 2x as big.
This doesn’t seem likely that that the two lights have the same capacities.
Anyone know the actual specs for the L1?
got both colors - funny how the color change with different lightsource
groupbuy: https://budgetlightforum.com/t/-/56752
new video available!
www.youtube.com/embed/rJ_oy5fZ5PQ
How do I get a discount code for the Pen L2?
the best prices can´t be public most times - so i have to put them behind the membershipagreement to stay private
ooor you send me a PM or mail as mentioned in my signature ;)
That Pen L1 is rather interesting. The specs listed are a little weird though - It looks to use a specialty internal USB charged 10900, but the text also says it runs on 10440 and 10400, depending on where you look.
I like that the Pen L1 is substantially shorter than a (2) AAA light.
I noticed those discrepancies, also.
I suspect that they copy and pasted from the C1 information and didn’t proof read very thoroughly. The published output specs are the same for the C1 and L1, and they probably shouldn’t be the same.
Those errors will confuse a lot of people.
Folomov Pen L1 webpage on Folomov's website
http://www.folomov.com/en/content/?141.html
It does look like it uses a really special-looking 10900 lithium ion battery, which has a built-in charging port (otherwise, no current charger can charge 90mm length batteries (maybe a magnetic charger with a low-charge current will work)
I wonder if the 10900 is about twice the capacity of 10440, since it looks to be about twice as long?
Or maybe can we substitute 2x AAA NiMh/Alkaline batteries (but voltage may be too low?)
Looking to purchase an Opus BT-3100 on banggood, but the code on your blog has expired
Nightwatch NI40 interest list started
Folomov L1 does not work (properly) with 2xAAA eneloop (low modes only)
just tested on mine
Thanks for testing!
Ok, I supposed if the 10900 battery goes bad, then another option could be to use a 10440 battery, and then use a dummy AAA battery to connect with it then…
That should work fine assuming lengths are proper.
too soon to market perhaps?
What product and why?
I can see in the description XHP35.2, suspecting a typo…
fixed the typo - thanks!
Amazon.DE: 50% auf Sofirn SP70 KIT
Servus mitnand!
Ich habe von Sofirn einige Codes bekommen für die:
Sofirn SP70
5500 Lumen CREE XHP70.2 LED
mit 26650 Akkus
bei Interesse bitte per mail anfragen!
Martin@m4dm4x.com
BETREFF: Amazon SP70 KIT deal
Signed on for the interest list of the Nightwatch NI40. :smiley:
What is the color temperature for the SST40 NW and the XHP50.2 NW? Is it 5000K or is the SST40 just a dedomed 6500K?
