Is there any way to disable memory mode on the SP32a?
I’m really tempted by the box-o-32s, but I’m rather cranky about having mode memory on by default.
No, it doesn’t have a way to turn off memory. It’s always a single click to turn the light on at the last-used brightness, double-click to go to the highest level, or hold for a few seconds to switch to the other UI style.
It has two UI styles — ramping and a discrete mode group. In ramping, it’s click for on/off, hold to change brightness, double click for high, or triple click for strobe. In the mode group, it’s mostly the same except it uses click to change levels and hold to turn off.
My “Loot Box” arrived a couple of hours ago. The lights are essentially just brand new lights. All mine are 100% in appearance & working order. A handful of batteries that are the same. All very well & securely packed, delivered promptly from ‘God’s Country’ to Alabama.
. You thought right… It surely is. :+1:
But after spending two summers, years ago; traveling around & exploring many of the more remote areas in the general vicinity of your “space rock”…. I can honestly say it is “God’s Country” too. Just a different slice than Alabama.
