Astrolux A01
I bought 2 of these first (Astrolux) Batch Grey.
MAGIC…… Just opened the one on my keys Soshine 10440.
They’ve Been on these since new. NO prob’s so far.
I got a coupla each, BLF 348 and Singfire They running on a mix of
10440. Ni-Cads and Duracell.
NONE give a problem. and I find minimal difference in output.
No matter which one I switch on.
Just ordered another 3 too. Yellow. Blue. and Red.
Different one on each keyring. So i know which keys I picking up hey.
House. Boat or car.
Does anyone know if you can get replacement glass for these? If so, what size and from where?
Thanks!
Dunno the size, but I got planar glass from FT and AX recently. Eg, needed 31mm, decided to chance 32mm, and it fit perfectly.
Kaidomain has lenses too.
My A01 lens is shattered as well, I don’t want to play with glass particles to measure the size….not this week.
I think it’s about 12 mm but I don’t want to make an order based on measuring bezel ID…
I just checked its 14mm so the 12mm might be okay?
so u can run a 10440 battery in this light or is there risk u fry the driver?
https://www.fasttech.com/products/0/10001022/5422711-14mm-ar-coated-glass-lens-for-led-flashlights-diy
The glass is 14 or the bezel is 14?
I measured the glasss as 14mm with a ruler
Awesome. Thank you!
Did you see the link I posted?
I did. That’s what I ordered. Hope it works. Thanks lightbringer.
In my plastic caliper the Astrolux A01 Glass seems like 13.5mm
Thank you both for the measurements. :slight_smile: I wonder is the maker changed the lens at some point…
I fail to find a 13.x mm lens anyway so I think that a 14 mm one is the best bet. It can be filed if too large…though I hate filing.
I see the same diameter also available from KD, in 1.5 and 1.6 mm thicknesses. But much more expensive. I think I’ll go with fasttech (and BLF coupon which shaves 9 cents off the price) :slight_smile:
Rats! You mean I overpaid by 9 cents?!? What is this magical BLF coupon I’ve been missing out on?
I had one of these on my key chain for maybe a year. It served me well enough. It never failed but there were things I didn’t like about it. First, the twisty mechanism operates by closing a gap but there is some play when not closed all the way. This means that the mechanism can be triggered by pressure when close. Because it is a multi-mode flashlight, it could cause rapid mode change while twisting one-handed. I already hated having strobe in rotation but this meant occasionally activating it. This problem was aggravated by the presence of firefly mode. I appreciate the situational value of firefly but as far as my normal EDC needs go, I almost never needed it. So I was already in the habit of double-twisting for usable light. I also didn’t like that “medium” used PWM, since that ended up being my most-used mode.
Besides that, I really liked the shape. It came in handy and I used it a lot. I was fond enough that I didn’t want to permanently retire it to a drawer. So I sent it to another forum member who I hope will give it a good home.
BTW, they are still advertised as having a 219B but I thought they changed over to 219C. Heck, I think they changed over before I got mine. This wouldn’t be the only case of a company switching over without mentioning it. Massdrop changed from 219B to 219C and didn’t update the product pages until I emailed them about it!
The coupon is “BLF” and it works for all flashlight related items, all the time, reducing the price by 5%.
I have 2 of mine in hand both running Li-Po 10440.
Both fine.
Also have 1 x BLF 348. and 2 x Sinfire.?
Neither are as interesting or handleable as the AO1.
219 B or C. (I have couple each of that too. old/new models)
does flat tops work in this light?
The positive contact in the driver side is flat so you might need a little blob of solder there.
