So those are the 21700 versions of L2 and C8+, right ?
Oh wow, very much interested in the L21
mostly yes
Ordered 2 x M21A
Thanks for the great price!
1 Ordered, thx.
I received an OUT OF STOCK notice from Banggood for the two M21A that I purchased.
their system says: Expected on June 20, 2019
maybe the order system offers you to cancel to avoid log waiting (that often collides with the presales)
do not cancel - tell them you want to wait
Yes, thatās what I did.
Thanks
Ordered 1 m21a. Thank you Martin!
What would be the best 21700 battery for the m21a? And the best place to buy it?
I bought some purple Shockli 21700 4500mAh high drain, (received them today) i will let you know if it works ok with the L21a when i receive it
Thank you!
Very tempting! Any chance of including the M21A host?
Has anyone done a review on the m21a? Also, Iām curious to know what the throw is.
Iāll probably take an L21A later this monthā¦ But just to mod it to a white flat.
Ok, received the L21a today and the shockli cells do NOT fit the L21a !
Drat, now i have two brand new cells which do not fit and have no use for.
It seems the diameter of the cells is too large. With my caliper i measured the inner diameter of the tube which is 21,5 mm.
The shockli cells have a diameter of 21,7 mm.
Drat, now i have two brand new cells which do not fit and have no use for.It seems the diameter of the cells is too large. With my caliper i measured the inner diameter of the tube which is 21,5 mm.
Will it help if you remove the wrapping?
Maybe, but i do not like to have a bare cell in my light, unless i would be sure there is another wrap underneath it, but it does not look like thatās the fact
I personally donāt mind bare cells. But itās a pity that they might not fit. I also donāt mind losing 200mAh for a genuine 21700 cell as Iām using in my 21700 Convoy lights. But damn, I almost bought Vapcell ā21700ā cells that apparently has the same problem.
Mine shipped out finally! Thanks for the code. Iāve got two brand new 21700ās sitting here charged and waiting.
Also, what is white flat? Iām assuming a particular LED, but I donāt know which.
