Kaidomain has lenses too.
My A01 lens is shattered as well, I don’t want to play with glass particles to measure the size….not this week.
I think it’s about 12 mm but I don’t want to make an order based on measuring bezel ID…
Thank you both for the measurements. I wonder is the maker changed the lens at some point…
I fail to find a 13.x mm lens anyway so I think that a 14 mm one is the best bet. It can be filed if too large…though I hate filing.
I see the same diameter also available from KD, in 1.5 and 1.6 mm thicknesses. But much more expensive. I think I’ll go with fasttech (and BLF coupon which shaves 9 cents off the price)
I had one of these on my key chain for maybe a year. It served me well enough. It never failed but there were things I didn’t like about it. First, the twisty mechanism operates by closing a gap but there is some play when not closed all the way. This means that the mechanism can be triggered by pressure when close. Because it is a multi-mode flashlight, it could cause rapid mode change while twisting one-handed. I already hated having strobe in rotation but this meant occasionally activating it. This problem was aggravated by the presence of firefly mode. I appreciate the situational value of firefly but as far as my normal EDC needs go, I almost never needed it. So I was already in the habit of double-twisting for usable light. I also didn’t like that “medium” used PWM, since that ended up being my most-used mode.
Besides that, I really liked the shape. It came in handy and I used it a lot. I was fond enough that I didn’t want to permanently retire it to a drawer. So I sent it to another forum member who I hope will give it a good home.
BTW, they are still advertised as having a 219B but I thought they changed over to 219C. Heck, I think they changed over before I got mine. This wouldn’t be the only case of a company switching over without mentioning it. Massdrop changed from 219B to 219C and didn’t update the product pages until I emailed them about it!
Not knowing about the next mode memory, I ordered 7 of the A01. Mostly for gift giving. Dang! They all have NMM, although 1 red one has changed from 2 hours’ recovery to just a few minutes for some reason. I never would have ordered them if I’d realized. And after writing to Banggood, their reply left me feeling like they just got the last money from me, ever.
Today 3 Sofirn C01S twisties came (Amazon order). Much nicer lights for just a buck or two more, and they work as they are supposed to (high, then low, and no annoyances).
I guess I can still give the Astros away to the unenlightened…
I bought two of the original copper edition gave one to my best mate then an old lumens edition which both of mine have seen no use except to try out. No patina for me lol.
If you lads are trying different lights with 10440 add to my old thread. Ill try and fix the pics up if i can log into flickr.
