Yeah, I agree with you guys; the final result is pretty amazing. :+1:
These should make killer gifts for the right people who will put them to good use.
Regarding the GITD o-ring. What would the dimensions need to be? Roughly speaking.
I know 42mm OD x 1.5mm GITD o-rings are quite common (Fasttech for example) but they’re obviously too small for our purpose. I think So the Q8 head is 59mm but the body is 50mm? So would something in the 50mm ballpark work?
Edit: Looks like I forgot what the LT1 looks like and how large the head is. So something closer to 60mm is probably needed? Or even bigger?
One of the largest I found was a “50mm” GITD o-ring from crazy-factory.
Due note they’re sized to fit snugly on plugs of the stated size hence the quote marks on the size. It’s thickness isn’t listed either so it might be a 1mm jobbie which would a bit wimpy.
Just for shit’s and giggles, here’s something a bit chunkier, a GITD hood latch which dimensions according to the description are 50mm OD x 5mm.
If someone’s interested in those, looks like they’ve got a discount on their website. 3$ for 2 and 5$ for 4 (instead of 6.5$ for 4 on Ebay).
A bit too expensive for me as they come from the USA. 13-15$ for shipping, oof.
I like the sleek look of the first prototype, but the new design is probably more practical. It seems it should weigh a bit less and it’s nice how the handle can be folded in. It might make things a little weird for how I usually carry it though; I tend to loop the handle over two fingers. Not sure what to think about the bumper; will have to see it.
I’ve read a bunch, but had a question. Is it possible to activate just one side of the lamp so that if you are holding it, you are not getting light back at you? Thanks and apologies if this was addressed.
I use a soda/beer can… Cut the length of the can, remove top/bottom, and remove about half the original circumference and re-roll. The inside of the can is a natural reflector and covers about half of the lantern’s beam ……. You can paint the outside if the “BUSH” label bothers you.
