I just noticed my jetbeam jet II MK has a centering ring that fits slightly loose for 3535 emitters. It might work perfectly for the 4040 without any modifications.
Do you think I need to regulate my output current to a safe level when used with a high drain 16340? Vapcell rates these at 6A but I don’t want to mess up a $10 emitter.
I am interested into your Q8 boards with OSRAM KW CULNM1.TG. Can you please help me find out some information about the LED?
What LED is this exactly? Is it a "small 1mm² OSLON BOOST HX or something else? It is nowhere to be found on OSRAM's website. They only list the 2mm² KW CULPM1.TG (Boost HX).
Do you have a datasheet for the KW CULNM1.TG LED? I would like to know more about its maximum current sustainability.
Will you be offering the Q8 MCPCB with KW CULPM1.TG (Boost HX 2mm²) in the near future?
It's interesting that the big 4040 Boost HX (2mm²) can sustain 6.6A of current and ist rated 20.1W of power while its "predecessor" the 3030 "White Flat" 2mm² CSLPM1.TG sustains 5A but is rated with only 4.38W.
The main purpose of this LED was (it seems) automotive headlights, but it looks like potential big customers did't like the size of LED package, for whatever reason, or cost.
Hi L4P,
have you contemplated put Boost HX in your store for preorder?
That way people could pay you in advance and, if it is reached the 2000pcs goal, you could purchase a reel.
I don´t know how much interest is on that LED, but SST-20 GB reached 1000pcs in about a week.
Order # L4P2066 received. Everything is supremely decent. Packaging, delivery time awards all praise.
Where can I read about the correct switching of thermal control, wire wiring, as well as setting up the driver?
Respectfully ….
Yeah, people are conditioned for Group Buys around here. I think if an interest list were started, in a new thread, and given enough time, you could easily reach a couple thousand or more, especially considering that the Boost HX is one of the most highly anticipated emitters in recent years. I’m not surprised at all that the “lesser” version didn’t get much interest.
Hello I would like to purchase six LUMINUS SST-20 4000K 95CRI LED (SST-20-W40H-A120) – Bare and two L4P 3XP Triple 20mm DTP (Direct Thermal Path) Copper MCPCB. I wondering if you offer a flow service to flow the leds onto the board? Thank you!!
