Texas Ace, that was how I read the graph as well. I think I only have about 20 R9080âs left and then I will be pulling them from older builds for newer builds. In place of a flash for macro, I am usually running in the upper half of the output range for the R9080âs to get good output. The output levels on these may not require that they are driven hard, thus dropping them into the crap light range. I did order 10 of the FD2âs to test with in general purpose triples and singles. I am not expecting the best tint, but at higher output they may be impressive.
I may build one of the FW3Aâs with R9080âs as it is my favorite all time EDC led.
At higher output levels the FD2 is a pretty nice tint compare to other options on the market. Just at lower output levels it suffers some.
The sST-20 in general really does best with FET drivers. Once the FET kicks in the tint improves drastically so PWM FET is my go to for these for sure.
Yeah, this is annoying to me as well. The best way around this is to use a PWM FET driver. The only real downside is the lack of moon mode and the ramp is not smooth at low levels. Which is why a second channel is needed for those modes.
It does, I build my scene flashlights with wide optics and very limited mode selections. The camera is very easy to adjust to the inbound light levels. The R9080 really makes colors pop and that is why I use them. I suspect with the FD2 I will end up running singles at 3.5 to 4.5 amps and triples will only be used in FET modes. The R9080 lights will be used when lower output levels are needed.
How about a MCPCB that splits the LEDs into like 3 banks and then only ramps up 1 bank at low levels, until you pass a threshold and it turns on the 2nd and 3rd bank of LEDs
That would be really neat. I would want about 2 amps per channel across a triple for the R9080âs and maybe what 3 amps per SST-20? Getting all those wires into the head of a light might be a challenge and then there is the driver⌠3 FETs with some PWM control each.
While technically possible it would add a lot of complication for minimal benefits in practical terms.
An FET channel can be PWMâed down to around ~150-300 lumens in most cases (technically much lower then this but you loose resolution that low and it can be inconsistent light to light). So above that the tint will be good. Creating multiple channels for under that lumen level would be very communicated and not help all that much since the tint would still be bad.
I fixed my FW3A-SST20 so it doesnât look green any more. I added a Lee 248 âhalf minus greenâ filter between the optic and the lens.
Itâs a really nice shade now, but the lumens are even lower than the already-unimpressive numbers it started with. I measured three lights just now at the 1x7135 (350mA) level in my lumen tubeâŚ
XP-L HI 3D: 143 lm
219B 4500K: 91 lm
SST-20 4000K w/ minus-green filter: 70 lm
The efficiency is pretty bad. 110 lm/W for XP-L HI, 70 lm/W for 219B, and just 54 lm/W for a rosy SST-20.
I also tried a Lee âquarter minus greenâ which would increase the lumens a bit, but I didnât think the effect was strong enough⌠so I went with half minus green instead.
As a nice bonus, the pink filter is clearly visible through the lens, and it looks really nice inside the purple FW3A host.
