I bought one and it’s failed completely after only a few uses. Rofis won’t do anything about it. They won’t even return emails or messages. Stay away is my advice.
Decently built lantern mosquito killer 2 in 1. Very easy to mod and actually kills mosquitoes and all sorts of small flying bugs. Mine has a triple 219b 90cri and 3,500mah 18650, only downside is the noticeable pwn in lower modes. Lightning deal 14.99
Bah. The numbers seemed “off” when I tried ordering 2 (vipon + 15% off), went back to change the qty to 1 instead, just to see what if anything changed, and when applying the vipon code, “this code has already been used”.
Yes, if they have any presence at all in the state you are taxed.
edit; actually I just looked and I guess AL is one of the states that went further and just allowed all big internet sellers to charge tax since no one properly reports it.
I don’t have the Tool AAA, only the AA versions. I do have an EDC01 though. I’d say the main differences are twisty vs clicky and TIR vs reflector. Oh, and pocket clip vs none.
I like my EDC01 for sure. It’s so small, I usually keep it clipped (suspension clip) to my shorts every night while sleeping. Granted, I swapped the LED for a 4000K Luxeon V2 and stripped the anodizing (I bought the blue, and it was more of a Tiffany blue than I thought it would be… so now it’s raw aluminum).
The stock 18650 is wrapped along a protection PCB and has 2 wires out. I simply removed the tabs from the included cell and soldered a new one in. Soldering required but it is as easy as it gets when it comes to replacing integrated 18650 cells. Led swap is pretty straightforward with enough room for triples or quads.
