【convoy】H4 and B35AM options are updated
production time of driver is about 10-15days
do you colors for other model ?
Sst 40 5000K kick the deal breaker away!
I’d love to see an orange C8+, or maybe the L2 or L21. Something very “search and rescue” about an orange thrower.
Hello Simon, I am very happy to see you added quality 18650 cells. Can these cells be added to any order
S2+ and S21A are not the same, size of reflector is different, heat sinking (S2+ will be the hottest, so to run 3A+ better get something else), not tested L21A and L2, but everything with XPL-HI has more throw, as it is dedomed LED
If I put the battery into the flashlight, I can mail it to most countries via Neatherlands post air mail. In addition, a small number of countries can use epacket, of course, the shipping cost is also expensive.
I can mail the battery(only battery) to a small number of countries.
I can use epacket to mail the battery directly to US
4000K :sunglasses:
@Simon - the XHP35 driver is a 1C boost driver or multi-cell?
Driving the XHP35 HI at 2.3A is very good. All the other single cell 12V output boost drivers I’ve seen have been about 1.5A max. Very much looking forward to this driver. I’m currently waiting on my first L21A to arrive and I’ll order a second for the XHP35 HI when it’s released.
For what it’s worth, I would prefer a 5000K or 5700K XHP35 HI over 4000K. I tend to find 4000K a bit too warm for a thrower but find the 5700K in my ThruNite TN42 just perfect. Either way, it will be excellent. Keep up the great work, Simon :+1: .
Very good news, Simon :partying_face:
Another question: does L21A support all common 21700 cell sizes (the thicker ones as well), or just a few selected ones?
(I am looking for higher CRI XHP35 HI, and I will definitely try a L21A build with it)
Simon, you are awesome. Behaving like a Santa Claus - making all BLFers wishes come true. Incredible.
What’s gonna be next? How about adopting E21A?
Thank you Simon, this is great news. This is why Convoy is my go-to brand, I always recommend your shop to people I know.
A heat resistant 7mm outer diameter circular gasket for E21A would be awesome (it should have approximately 3mm inner diameter, and the hole should be circular, as phosphorus layer on E21A is rather sensitive to mechanical stress, while gasket is rotated during assembling). Once this is completed, that would support many builds - currently no one did this for us yet.
E21A is currently the best high CRI emitter for flashlights - a bit lower powered, than SST-20 high CRI (only about max. 2A per emitter), but the offered CCT range is unmatched by concurrent offerings :smiley:
Hi Simon,
Do you have or plan any flashlight able to use all of AA / NiMH / 14500 li-ion (voltage range 0.8…4.4V)?
Interested in both one and two cell variants.
Hey Simon, any chance you have a Code for the “Bluish Gray” S11 on AliExpress? I assume that is from your store.
BTW, is the Bluish Gray actually a different color than the standard Gray Convoys come in? Thanks!
Are the XHP35 drivers going to be sold at the Convoy Flashlight store in the near future? I’m guessing a 17mm board would be too small to adapt the items required for that driver?
Hey Simon. Can you offer the M21A with a good 21700 battery? I can’t find them anywhere that ships to my country.
pity that only support LG SONY TESLA SAMSUNG 21700 (DIAMETER LESS THAN 21.5MM)
