Ansmann AAA 1100mAh (Silver-blue)
Official specifications:
Nominal capacity: 1100mAh
Minimum capacity: 1050mAh
Maximum continuous current: 3000mA
Standard charge: 110mA
Quick charge: 330mA
Fast charge: 1100mA
Recommended charge termination: 0…5mV, 0.8…1°C/min, 45-50°C
Trickle charge current: 10…50mA
Continuous overcharge: <100mA 1year: no conspicuous deformation and no leakage
Self discharge: >60% remaining after 28days at 20°C
Maximum temperature raise at different discharge currents: 1A:+0,1°C, 2A:+0,1°C, 3A:+0,1°C, 5A:+0,1°C
This is high capacity cells from Germany
The two cells match fairly well.
Internal resistance measured by pulsing 0.5A on/off.
Conclusion
These cells are some of the highest capacity AAA cells, but because these cells are not low self discharge they are best used for equipment that uses some power and is used frequently.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
