OK, so a simple light with high quality components and high build quality.
No USB and no LCD, but a plain led indicators as batt-check, like this one:
This is the most simple UI that I could think of:
https://i.imgur.com/6zPTNsN.jpg
Immediate thought, may or may not be sensible
Put the two e-switches under a single flat rubber cover, with a space between them. Put a roller on the bottom of a captive slider. Two detents on the slider.
Off is the centre position, with the slider on one of the two detents and the roller on the gap between the switches so nothing happens.
Push forward is momentary-on. No detent there, the roller engages the front e-switch, with a spring pushing the slider back to the centre-off position when the user releases it.
Push backward is constant-on, the roller engages the rear e-switch, with the slider on the other detent. Push forward to the centre-off position to turn the light off again.
Extra constant-on modes are possible by having extra rear e-switches in line, each with its own slider detent.
BREAK
Alternatively, you could do it magnetically with a magnet in the slider and using reed switches (no parasitic power requirement) instead of the constantly-powered Hall Effect sensor that continuously-variable controls have to have.
Too complicated, too many movables. Rubber boot with a stiff top. Pressing down on the front activates the front switch, and v/v for the rear switch.
Doesn’t need to quite literally be a slider, ’though if you want to “contour” the boot to be somewhat concave (press the edges) or convex (somewhat of a slider, but nah).
Now, you wanna take that rocker switch and put a sort of lever sticking up-top like a paddle switch, that’d work, too.
Eg:
to show the (rather bulky) actuator.
Yeah, too complicated for the low-price brief, that’s for sure.
Your way is better, especially since I’ve remembered that rocker switch mechanisms are available in on-off-momentary arrangements too
Yeh, anyone who has power windows (or locks) in a car has seen a switch that’s center-off, momentary-up, momentary-down.
I concur.
Remember, you’re talking about something intended to be assembled chabuduo by Chinese workers from cheapest-source part suppliers.
If you are German or Northern European in general, you are likely used to things being done according to specifications and high standards. You probably wouldn’t expect less than 100. As an American, you are may be used to a little more wiggle room. Not everything is quite as perfect, for example with regard to workmanship, but still very good, like 90-95.
Not so in China. In China, the typical approach is summed up in one word: “chabuduo”, meaning “nearly” or “almost”. For most Chinese it also means “good enough”. You will hear this term a lot.
KISS. You need this to be far simpler and more robust than you want to imagine, to take up the slack.
Good thing flashlights aren’t life safety critical.
Oh, wait ….
I have a feeling that my flashlight UI designs aren’t very well aligned with the popular opinion, but Artur asked me to weigh in so here’s my input. This interface setup is what MELD uses in lights with dual switches:
The only difference between the two switches should be that one is for UP and one is for DOWN. Any user input that could have directionality will follow the UP/DOWN designation of the switch that is being used. For any other user input, both buttons should function exactly the same.
For example, here’s a simple ramping UI with dual switches that follows this philosophy:
Click either button to turn on. Click either button to turn off. Press and hold either button from off for momentary usage. While on, hold down either button to ramp; UP button goes up, DOWN button goes down. Double click UP switch shortcuts to max; double click DOWN switch shortcuts to min.
This can be extended to further functions with extended commands (triple click, click-click-press, press both simultaneously, etc.). In any case, a command that doesn’t have any up/down association (on/off, battery check, options menu, etc.) doesn’t matter which switch is used, they both act the same. Any command that does have an up/down association (ramping, shortcuts to high or low, advance through menu options, etc.) will choose the direction based on which button is pressed.
:+1:
Interesting light but from my point of view:
- UI is too complicated
- I fear that too much features might compromise the reliability
- it will not be a budget light
- it might end up bulky
Just my 2 cents. I know I will still buy it if it’s not too expensive.
That would rock my ’fro, yes.
I think we will stay with solution from post #89
Hi mate! Sorry, didn’t have the chance to answer your PM yet
However, I guess I will forget my options and look at this suggestion :
[…]For example, here’s a simple ramping UI with dual switches that follows this philosophy:
Click either button to turn on. Click either button to turn off. Press and hold either button from off for momentary usage. While on, hold down either button to ramp; UP button goes up, DOWN button goes down. Double click UP switch shortcuts to max; double click DOWN switch shortcuts to min.This can be extended to further functions with extended commands (triple click, click-click-press, press both simultaneously, etc.).
This seems to me as a very good solution!
Please note that my opinion doesn’t disregard the your options posted before. However, it seems to me that for a dual light switch it may be reasonable to consider!
When I have the right time, I will answer your PM Sorry for the delay!!
I like the vast difference between the various UIs being proposed. However, I can't really find myself getting behind UIs that make extensive use of press-and-hold as an action, or that rely heavily on "click X times" as a meaningful interaction.
I think the UI mentioned and compared to MELD was pretty interesting. One of the first UIs I thought up, when addressing this light, had about half of the base concept the same: Both buttons do the same thing. In my case, I was building around each button controlling a separate emitter, which was pretty neat and led to intuitive interactions once you understood the basics.
As far as the UI most recently proposed by Rost in post 89, I don't think it would be something most people can just pick up and use. Sure, it would probably be easy enough for someone who read the instructions, but that's not the same thing as intuitive.
It needs to pass the Enderman’s Gramma test.
A 3-position slider can be used to turn the light off|low|high and that’s it.
Slide for off-low-high would be cool. (and it will make this light more attractive than my MT22A)
It’s also an easy way to figure out in the dark.
I found this light: Epsealon Red Bullet. We could use such a slide switch in our 2*AA light.
This slide switch is too bulky: Seac Sub R3, but in our light it could be more flat.
How about a spring-loaded switch? Second after slide switch most intuitive solution IMO.
Something like this one: Seac Q5
See all the X-Rays on apneapassion.com
or one of these: Mares-EOS-4RZ & Mares-EOS-5RZ
https://www.simplyscuba.com/products/mares-eos-5rz-torchThe Mares EOS 5rz Torch is a decent size and powerful waterproof torch with a rechargeable battery an...
I don’t see any reason not to use buttons. I understand that you want to make this light stand out from the crowd, but going against too many conventions at once is a great way to add complexity,create issues, and alienate any potential buyers.
