Yes.
@Barry, make this light with the LH351D 90CRI.
And yes, there are 1100mAh 18350s now.
Yes.
I like the short SC31 too but I like it better if the short battery tube is fully knurled instead of just a small section.
Barry, if this implies that a new batch of SC31 is made, can you do a small change in the user interface? : when the light is off, a long press goes to the lowest mode (instead of breathing switch light). For the breathing switch: triple click on/off with memory.
This would be better for many people here.
A good UI and eventually a shorter overal body would be great!
I use my SP32A with a convoy short tube and the UI (not starting in moonlight mode but still having memory function as the SP10A/B) is the only thing that makes me not use it as much as I’d like!
So, make a right choice and shorter body and you’ll have a nice light!
EDIT: make it triple!
I actually changed the LED in my sc31 to an sst-20. It’s OK but I think I’m going to put a Luxion v2 in it next. They usually work pretty well where an XPG is used. I like the warmer tints anyway. Great little light with the 18350 tube. Really wish more 18500 lights were out there. I have a lot of 18500’s that are going to waste away.
Barry, how about making some 18500 universal tubes for the SC31, SP32 and SP31? I have about 15 of these lights all together and would buy a few. I think the 18500 makes for a great length for a lot of these types of lights for EDC. Plus you typically get a little better run times with the little bit of extra capacity.
@ Djozz;
That would be a winner, option to enable / disable switch lite.
Personally like the the SP33 UI, but not so the SP10A.
The former works well for a handheld torch (single click ON/OFF, press and hold for modes, double click for turbo + click to return last mode); and the latter because of the long press to OFF which induces errors as Moonlight when returning to pocket. Any other variant without long press to OFF, and a long press from OFF to Moonlight is welcomed
@ HONDARIDER;
I had made some extension with a solid plastic 18mm dia, x 15mm thick stub that I cored and threaded / countersunk screw. Using in one of my lights but not the same capacity as true ’650s.
I have some spacers I bought from overready. They work great but it’s the length of the 18500 that I like. I don’t use my lights a lot through the day or night so runtimes are not a huge requirement for me. At least for EDC anyway.
+1
I would buy at least one.
A kit includung a 1100mah 18350 battery would probably sell well.
+1
@Barry, make a Nichia E21A 5000K version as well please.
I mean all of the work for this light is already done! Just Lego the pieces together, throw in a battery and take our money!
How interesting or viable would be to make it as a triple OR with a shorter reflector and bezel?
Just to make it shorter than the SP32A with a short tube!
this 18350 tube is compatible with SC31, SP32A V2, SP31V2
It’s even compatible with C8T and SP31T. ;-)
Barry, can you please offer the single 18350 tube for sale at Sofirn‘s shop on AliExpress? On TLF I saw that people would like to buy it separately. Thank you!
I’ll buy 4!
I was successful ordering a couple of these short tubes via Sofirn's CS team on AliExpress (Cissy). If you click on "contact seller" you can send them your inquiry. I paid $ 15,80 for 4x SP33 26mm DTP boards and 4x SP40 18350 short tubes including $1 off discount, PayPal marketplace fee and e-Packet shipping. Assuming that all parts are sold for the same price, the battery tube would cost around $ 2,00.
I’d definitely be in for a few.
You don’t want to know how many shorty tubes I have for my S2+es, and in how many colors. :person_facepalming:
Not only, aliexpress. If you contact sofirn on BLF or TLF, tell what you wanna order. You will get service too!
Technically speaking, not quite but close. This is Henrik's latest test of the “1100mAh high discharge cell from Shenzhen Yongde Lixin Energy”: Test of Shockli 18350 1150mAh (Black) 2018
A test which is also outdated: Vapcell INR18350 1100mAh retested by Mooch: shenanigans again
Am I presuming both Vapcell and Shockli cells are the same? Sure.
We do not really know what current capacity and discharge rate those cells are delivering now. Maybe we should ask Henrik to get new review samples from Vapcell, his small cell queue isn't crowded.
Cheers :-)
1100mAh down to 2,5V.
