First pic is the original Switch rubber boot from the ZY-T08. On the second pic you see the original 1288 switch that i would like to change to the one on the pic. To make space for it i dremel milled the ring where the retaining ring is screwed in down from 5 to 2mm. After that i noticed that the Convoy S2+ metal switch boot could fit. So i grinded a 1,5mm metall ring to fit the Metal switch boot to the tailcap. And to make it look a bit better i added a o-ring. One is a simple black o-ring the other a blue GITD o-ring. The metal switch boot sits 100% flush with the tailcap end. So tailstand is possible and it feels soooo nice compared to the original 1288 with rubber boot. Now i have to get the new pill and the 3V XHP-50.
Put a small trit in the clip of my s mini ti.
I have a couple m43s laying around. Reflowed one from 219c to 219b. Amazing rose flood.
I replaced the XP-L Hi star in my Klarus Mi7 with a SST-20 (4000K) from Simon/Convoy (had to reduce the diameter of the star a bit).
Ultra-basic beginner mod but it’s where I’m at
Lao Tzu: The journey of a thousand miles begins with one step’.
Brass lighter mod I did yesterday.
Wow nice build! You make the spacer?
Super nice!
I am contemplating a similar build with the M21A.
Beam shots??
Stunning!
You give me idea for my unused zippo :+1:
Is that a switch (the cylinder shaped stuff)?
I’m thinking about using reed (magnetic) switch for my future build.
Yes .
Yes, but only for myself, it’s just a hobby …
I’m not going to make money on it.
Yes it has three switches, you can see it working in the linked thread :+1:
Switch PCB is modded back to 2P battery. In the past i removed the copper layer on 60% of the switch side. So i had to fix it. Used a 0,1mm copper sheet, soldert 2 layers together and glued it on the pcb with thermal glue. Then i were able to install the new switch and the new metal button. Needed a spacer to make it work nicely. But i did not have the right material on hand. So i had to make one brass spacer 2mm and one copper 0,5mm. Soldert both together and made it fit to the aluminium Tailcap. Now i am waiting for some GITD powder to fill the space arround the metal switch button. And the new pill from Kirill that seems to be stuck in customs. But untill then i will remove the red marked area on the pics to make the tube more flat on both sides.
Put some magnets on the Sofirn C01’s I have. Bought here (Convoy Store):
Used a drop of super glue to fix the magnets in the lights!
https://www.aliexpress.com/item/D5-3-magnet-for-18650-flat-head-battery/1590874652.html?spm=a2g0s.9042311.0.0.3da24c4dkz3qek
Rebel Lime in a Convoy C8+ on a LD25 3A driver. I wanted to use one of my old D80. But the 17mm driver was not a good fit. Even with almost empty battery the rebel lime is pulling the full 3A. It is still not 100% centered. But it is looking fine as it is now.
So… what is Rebel Lime good for? I mean, is it an aesthetic choice, or is there a practical purpose?
To put out a lot of lime colored light :sunglasses: Kidding! I really have no special use for it. But i find it more interesting to work with a led i never used.
And i like the green/lime colored leds. So i had to get at least one Rebel Lime. To bad that the MCPCB is a Aluminium board and not a Copper DTP
Waiting for new boards from Neven to complete a few more color light mods.
I have a load of (20mm) Rebel Sinkpads doing nothing, I can send you some if you like.
With the rebel does the star have to be a little off center to properly center the dome of the LED?
