GT Mini is great - get a Flat White (and gasket) on a 20mm mcpcb from intl-outdoor, mtnelectronics, swap that out, and watch the candela go through the roof.
If you’ve got the gear and are also feeling tricky, reflash with Anduril
Oh! Well if you get the White Flat on 20mm (here’s an example), then you just open the top of the light, drop out the reflector, desolder the old one (positive and negative wires), and solder the new one in. You’ll need thermal paste too for between the MCPCB and the light itself.
I don’t have any pictures of all opened up right now, but can probably take some in about 5 hours or so. I still need to order my white flat though
EDIT:: Although the led4power link doesn’t look like it has gaskets. intl-outdoor and mtnelectronics do though. Because it’s a 3030 emitter, getting a gasket is a bit harder…
Sounds like it - the tailcap is double spring where the driver side is a single (albeit shallow) spring. By bypassing it or doing a double-spring mod you should get more light, but it’ll just heat up faster, and not be super noticeable anyway.
Looking at TA’s XPL HI review, it seems that going from 4.5A to 5.5A is only ~ 160 extra lumens, or ~11% more (that’s on a CW emitter) - only slightly noticeable. But going from 4.5 to 5.5A on a flat white, it looks like you actually lose about 40 lumens , or around 4.5%.
Either way, if I can hit 4.5A consistent with a flat white, I’m happy and with Anduril, I’ll be far happier than with any of the UIs I’ve found on Convoys so far.
I want to buy the flat white and a GT Mini, but I am guessing a driver switch would be needed also for this mod because it is going to push more than 4-4.5 Amps. Is this correct?
If I did get the new C8 the tan version, what is that driver pushing in amps? Can I just buy a flat white and install it like I would the GT mini, just do an emitter swap for the flat white, and if so is it going to use the 20mm also?
This is my first mod on a factory light without building it from the ground up and only did that a couple times.
