Do you have any deals for the Acebeam w30?
Hello my dear friend!
welcome to my newest groupbuy:
(the links take you to the shop for detailes information)
Blunish Gray Convoy S11
with SST40 or XHP50.2
https://docs.google.com/forms/d/e/1FAIpQLSdkuDAN5mngPhesFdZaHpzt7Uf5wIGQkLG3g6hIQeK3KPJtdw/viewform?embedded=true
Hello my dear friends!
I got some new deals and a groupbuy for you:
(ALL deals are available in MY DEALS LIST FOR MEMBERS)
Convoy S3
7135*8 XM-L2 U2 1A / T6 4C 3/5Modes EDC LED Flashlight 18650
CODE: BGCCS3 PRICE: $10.99
NEW Convoy L2
XPL HI Two Cells Version – 1000LM 26650 4Mode LED Flashlight
MANY LED CHOICES!!!
CODE: BGMODE PRICE: $34.99
HaikeLite MT07 Buffalo
XHP70.2 8000LM CW/NW
High Power LED Flashlight
Upgrade Version
CODE: BGEMT07 PRICE: $64.99
ADEASKA A10 Mini
USB Rechargeable Portable Magnetic Li-ion Battery charger
now in PRESALE US$ 4.99
Nitecore P30
Xp-l Hi V3 1000LM Long Range LED Hunting Flashlight 618M
(Deal is available in MY DEALS LIST FOR MEMBERS)
HaikeLite HT08
XPL HD 5000K 850Lumens Mode Set Zoomable Tactical LED Flashlight
There's something odd with the MT07 "Buffalo". Banggood says the CW is 8,000lm (N4 flux bin) and the NW is 4,500lm only (N2 flux bin). I wonder what "upgrade" version they are offering? HaikeLite could have used the P2 flux bin for the MT07 as they did with the upgraded MT09R. Maybe Banggood's got wrong information listed on their website?
It needs to have a new driver to produce something near 8000 Lumen. But I dont think they have another because the TA-Driver is designed for one switch and this flashlight has two switches of cause.
I have modded mine to a Lexel-Driver and 12V MCPCB. See this flashlight as a modding host and you will get what you want.
Another problem of my MT07 was that the reflector came loose. So I had to add a O-Ring between lens and reflector, but I didnt had one in the correct size, so I used two opened C8 rings.
… some pictures: https://www.taschenlampen-forum.de/media/albums/haikelite-mt07-mit-lexel-treiber-6a-12v.2236/ (I changed the resistors to something above 7A from the buck-driver.)
Danke Dir Wieselflinkpro!
new flashlight on the way!
Imalent DM70
many more pictures and specshheets:
https://m4dm4x.com/imalent-dm70-announced/
That is a cool light!
Do Imalent lights allow led swaps? (ze glue situation?)
I agree. Reasonable sized and powerful. Hopefully it’s available with a NW emitter.
4500 lumen from a boost driver? Hmmm…
Since most max out at maybe 3500, I’m quite skeptical.
+1 for NW option. If so I may have to purchase this!
PBWilson: djozz:That is a cool light!
Do Imalent lights allow led swaps? (ze glue situation?)I agree. Reasonable sized and powerful. Hopefully it’s available with a NW emitter.
Agreed. I like most of what I see on that light, but I have a box full of lights waiting for me to get around to replacing their cool white LEDs. I don’t need to add another light to that box.
M4D M4X:new flashlight on the way!
Imalent DM70
DN70 reaches 3800 Lumen. Its a similar Watt-region with the “new” XHP70.2. So its realistic.
JasonWW: M4D M4X:new flashlight on the way!
Imalent DM70
Since most max out at maybe 3500, I’m quite skeptical.DN70 reaches 3800 Lumen. Its a similar Watt-region with the “new” XHP70.2. So its realistic.
Where did anyone measure 3800 from a DN70?
Wieselflinkpro: JasonWW: M4D M4X:new flashlight on the way!
Imalent DM70
I in my Sphere. I hope its good calibrated, compared to some other spheres I got similar readings with some identical flashlights and other readings with the same flashlight model.
I think the reviews on the DN70 maxed out around 3300 lumen. Most 26650 70.2 lights exaggerate their output. Also, 3800 to 4500 lumen is a very big jump for a boost driver.
Today i present you 3 new deals:
-> my links take you to the shop for more Info
-> use the forms to participate or just check my dealslist
JETBEAM JET-KO02
XHP35 1800Lumens 6Modes
USB Charging 21700 EDC Flashlight
Specifications:
Emitter Type: XHP35
Peak Beam Intensity: 18225cd
Max Output: 1800Lumens
Range: 270m
Mode: Turbo, High, Middle, Low, Eco, Strobe
Lumens: 1800LM, 1060LM, 360LM, 80LM, 12LM, 1800LM
Runtime: 1h55min, 2h, 6h45min, 27h, 140h, /
Battery Configurations: 1 x 21700 Battery (Included)
Impact Resistant 2m
Waterproof: IPX-8 Waterproof
Weight: 88g
Size: 130.3mm x 27.1mm x 27.8mm (Length x Diameter x Tail Diameter)
Haikelite MT40 for $ 45.99
SST-40 7Modes 8000Lumens
High Brightness 18650 Flashlight
Specifications:
Emitter Type: SST-40
Light temperature: 5000-6500K
Max Output: 8000Lumens
Mode: Low, MediumⅠ, Medium Ⅱ, High, Ultra High, Strobe, Ultra Low
Lumens: 200LM, 1300LM, 2800LM. 4500LM, 8000LM, / , 2LM
Runtime: 30h, 12h, 300mins. 180mins, 140mins,/ , /
Battery Configurations: 4 x 18650 Battery (Not included)
Weight: 469g
Astrolux FT03 for $34.99
XHP50.2 4300lm 735m
NarsilM v1.3 USB-C Rechargeable 2A 26650 21700 18650 LED Flashlight
Specification & Features:
Emitter: one LED, cool white or neutral white , mounted on copper DTP MCPCB
Color temperature: cool white: 6000-6500K; natural white: 5700K
Flux: 4300 lumen
Intensity: 133,000cd
Range: 735 meters
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
use my CODE: MFT03X to lower the price to: US$ 34.99
