M4D M4X deals - Astrolux WP1 and WP2 LEP
There's something odd with the MT07 "Buffalo". Banggood says the CW is 8,000lm (N4 flux bin) and the NW is 4,500lm only (N2 flux bin). I wonder what "upgrade" version they are offering? HaikeLite could have used the P2 flux bin for the MT07 as they did with the upgraded MT09R. Maybe Banggood's got wrong information listed on their website?
It needs to have a new driver to produce something near 8000 Lumen. But I dont think they have another because the TA-Driver is designed for one switch and this flashlight has two switches of cause.
I have modded mine to a Lexel-Driver and 12V MCPCB. See this flashlight as a modding host and you will get what you want.
Another problem of my MT07 was that the reflector came loose. So I had to add a O-Ring between lens and reflector, but I didnt had one in the correct size, so I used two opened C8 rings.
… some pictures: https://www.taschenlampen-forum.de/media/albums/haikelite-mt07-mit-lexel-treiber-6a-12v.2236/ (I changed the resistors to something above 7A from the buck-driver.)
Danke Dir Wieselflinkpro! :+1:
new flashlight on the way!
Imalent DM70
many more pictures and specshheets:
https://m4dm4x.com/imalent-dm70-announced/
That is a cool light!
Do Imalent lights allow led swaps? (ze glue situation?)
I agree. Reasonable sized and powerful. Hopefully it’s available with a NW emitter.
4500 lumen from a boost driver? Hmmm…
Since most max out at maybe 3500, I’m quite skeptical.
+1 for NW option. If so I may have to purchase this!
Well, this may be a therapeutical flashlight after all ! I may need it :innocent:
Agreed. I like most of what I see on that light, but I have a box full of lights waiting for me to get around to replacing their cool white LEDs. I don’t need to add another light to that box.
DN70 reaches 3800 Lumen. Its a similar Watt-region with the “new” XHP70.2. So its realistic.
Where did anyone measure 3800 from a DN70?
I in my Sphere. I hope its good calibrated, compared to some other spheres I got similar readings with some identical flashlights and other readings with the same flashlight model.
I think the reviews on the DN70 maxed out around 3300 lumen. Most 26650 70.2 lights exaggerate their output. Also, 3800 to 4500 lumen is a very big jump for a boost driver.
Hello my dear friends!
Today i present you 3 new deals:
-> my links take you to the shop for more Info
-> use the forms to participate or just check my dealslist
JETBEAM JET-KO02
XHP35 1800Lumens 6Modes
USB Charging 21700 EDC Flashlight
Specifications:
Emitter Type: XHP35
Peak Beam Intensity: 18225cd
Max Output: 1800Lumens
Range: 270m
Mode: Turbo, High, Middle, Low, Eco, Strobe
Lumens: 1800LM, 1060LM, 360LM, 80LM, 12LM, 1800LM
Runtime: 1h55min, 2h, 6h45min, 27h, 140h, /
Battery Configurations: 1 x 21700 Battery (Included)
Impact Resistant 2m
Waterproof: IPX-8 Waterproof
Weight: 88g
Size: 130.3mm x 27.1mm x 27.8mm (Length x Diameter x Tail Diameter)
https://docs.google.com/forms/d/e/1FAIpQLScHHVhWu4xXwRQwFrn3EpwuK3FZPRShwMOqx39XzQKfmDHjiw/viewform?embedded=true
Haikelite MT40 for $ 45.99
SST-40 7Modes 8000Lumens
High Brightness 18650 Flashlight
Specifications:
Emitter Type: SST-40
Light temperature: 5000-6500K
Max Output: 8000Lumens
Mode: Low, MediumⅠ, Medium Ⅱ, High, Ultra High, Strobe, Ultra Low
Lumens: 200LM, 1300LM, 2800LM. 4500LM, 8000LM, / , 2LM
Runtime: 30h, 12h, 300mins. 180mins, 140mins,/ , /
Battery Configurations: 4 x 18650 Battery (Not included)
Weight: 469g
https://docs.google.com/forms/d/e/1FAIpQLSdQbuGM8lklrty6GqKv5RU7rZx_FjG4qxaAY26OK4Tvt3VU7w/viewform?embedded=true
Astrolux FT03 for $34.99
XHP50.2 4300lm 735m
NarsilM v1.3 USB-C Rechargeable 2A 26650 21700 18650 LED Flashlight
Specification & Features:
Emitter: one LED, cool white or neutral white , mounted on copper DTP MCPCB
Color temperature: cool white: 6000-6500K; natural white: 5700K
Flux: 4300 lumen
Intensity: 133,000cd
Range: 735 meters
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
use my CODE: MFT03X to lower the price to: US$ 34.99
it's Giveaway time!
Hello my dear friend!
Have you been lurking around a flashlight from banggood and been waiting for a deal to come available for long time?
So here is the chance to get a nicer price:
GET 12% OFF the whole flashlight section with the
CODE: BGTORCH
do not forget to search my page for a higher discout!
Can you renew the Convoy L2 sand / silver code at banggood?
i ask them !
enjoy my latest video!
www.youtube.com/embed/5_aI782m7B0
Time to say goodby and find a verdict for the acebeam X70 with its blinding 60000 Lumens.
also watch the quarry videos:
https://youtu.be/OLPdPQUQmS4 (stills)
https://youtu.be/rJ_oy5fZ5PQ [video from different angles)
and on my regular spot
https://youtu.be/s8tFIgf-Mf4
