Yeah.
The change in optic can be understood, but completely removing the lens?
I should’ve just ordered the 1st XP-L HI lights, then modded it with SST-20s.
This is getting more disappointing by the minute.
Yeah.
Anyone found sources for 23mm AR lenses yet?
The clip looks like it’s a different color on Lumintop’s site too. I really like the (acid wash?) dark finish on mine and would definitely prefer to have that when I buy more.
Well… if I buy more. There’s an Emisar D4 v2 coming up, and Hank doesn’t cheap out like Lumintop seems to be, even when he reduces the price (the D4 was introduced at $40, which was later reduced to $35). I was concerned that early FW3As might have problems that later ones would not, but it’s looking like the opposite is true.
I have seen car manufacturers change entire global supplier agreements (these were legal contracts drafted and signed for several years) because the new parts were a few US cents cheaper. The supplier was forced to sign a new agreement. Even pennies will add up over thousands of products and SKUs.
The glass lens and Carclo optic are probably expensive, not always easy to source, and have a 100% take rate (every light sold has them/needs them, so not optional).
While most of us probably don’t want a new lens/optics combo, from an engineering point of view it is a good way to ensure an almost identical product outcome while saving a lot of money.
You could also use a cheaper aluminum source, cheaper parts for the driver, a cheaper clip or drop it entirely, re-design the inner tube and make it skinnier and a more permanent part of the assembly, replace the metal switch with a rubber boot, and do a lot more!
I thought the same thing. I’m kicking myself for not just ordering all that I wanted right up front.
Yep.
I look forward to India’s manufacturers starting to make flashlights. Maybe their culture will be a better fit for meeting specifications/expectations.
Or not.
Hmmmm …. http://www.evereadyindia.com/flashlight/led-flashlights.aspx has the old type switch I’ve been missing ….
I think they should’ve just made the XP-L HI version more expensive, like with the Emisar D4.
They should’ve made the SST-20 version 29,99$US, and the XP-L HI version 39,99$US.
Not only would they have more profit margin, but they could use the XP-L HI to slightly subsidize the SST-20 version with a good optic and a lens.
The thing is, this is not a product Lumintop designed themselves. If Lumintop wants to change the design of say… the Tool AA, that’s fine as long as they don’t describe the old one to customers and send the new one. At worst, reviewers and community influencers will say it’s no longer a good choice.
The FW3A is a community design where volunteers did a bunch of work because they wanted it to exist and gave the result to Lumintop. Lumintop saves development costs and gets to build a product for a known market. The community has certain expectations as a result, though they’re not enforceable in the same way a contract is. The most extreme option would be someone running a second group buy to take the design to another manufacturer. They probably do have a contract with Neal, and we don’t know what’s in it. We do know Neal was expecting 10511s and glass lenses, and that’s not what he got.
Community expectations include a glass lens, a Carclo 10511 optic, a clip of the specified design, and a metal button. If Lumintop wants to make another light derived from the FW3A design using different parts and sell that at a different price point, nobody here will complain, as long as they keep making FW3As with the original design.
I hope the CU version still brings the carclo and glass lens
This is a very good point. I’m trying my best to be patient. I have plans for the additional 3 that I ordered, but they’re based on the original parts being there.
Optic drama !
They did that. The XP-L HI version was/is $36 in the ‘Group Buy’. The other emitter versions $30.
this is bad… why even change the optics to cheaper? makes no sense… sometimes i dont understand lumintops logic… I understand maybe now they didnt earn enough on all group buys or whatever reason, but just bump up the price slightly then and keep the Carclo optics instead.
Anyone else have problems with the discount code today?
OK…. :+1: …. But as far as jacking up the price of the XP-L HI “to slightly subsidize the SST-20 version with a good optic and a lens”……
To me that would not be acceptable. Let the SST-20 Version pay it’s own way. No sense in punishing those of us who like, or even prefer; the XP-L HI. We want the “good optic & lens” also remember.
ymmv
No more cost saving ideas please!
Well at least the new optic looks like it is a good match for the ruff MCPCB.
I believe the new optic setup is a bad move.
In theory the new optic should produce slightly higher lumens. No light is being lost from a lens. It’s all going through the one optic.
However, it’s not surprising that we here on this forum much prefer the glass lens (for scratch resistance) combined with the flexibility of being able to swap in any Carclo optic.
Personally, I wouldn’t mind if they added the new lens, but only as an option. Maybe get a $2 discount if you opt for their lens instead of the Carclo.
At least be able to purchase the glass lens as an option
I would never accept a plastic lens.
Not on a light like this.
If they want to mess up this light before it even ramped up, they can do this…
But I will no longer buy it…
It’s incredible with what type of problems Neal has to cope with…
Hope he gets them sorted out and this great flashlight restored to its original design…
