The pill (it was a D25A Ti) is brass and glued to the bezel, it cracked when holding it with pliers (with rubber strip around it) getting the bezel off. It is not round anymore either :person_facepalming:
But that is still nothing compared to wasting a good chunk of mokume after lots of machining work
This afternoon I thought maybe I could salvage the last bezel with a ti ring. I was thinking to cut it real thin once it was mounted, shape it and make it a bit of a feature. I cut 0.5mm off the diameter off the bezel and slipped this on…
However, the problem I mentioned above has come back to haunt me
I can straighten this out with a small vice but the pressure of the ti ring makes it all too easy to warp out of shape again.
Well I’ve got 2 more lives left to salvage a mokume bezel
Patience is what I exercise when waiting for deliveries or for a new light etc (….FW3A……). This is more like a niggling frustration that I can’t let go of
While I am not an expert in this and this is not my war, it could be that different density metal layers in the mokume does not play well with high rpm lathe crafting. If the stuff cracks in the lathe that means it is fragile for such treatment, or at least that very mokume is.
Maybe at ½ the speed, or ⅓, or ¼… going slow can be fast.
If it was just fragile the titanium mandrel would’ve been successful.
I think centrifugal force (high rpm) did played a part in the bezel bending open but the fact that it bent and ‘hung on’ indicates that it is not brittle nor fragile. What could be a possibilty is the weak points are weakened further by tiny vibrations. Vibrations that are caused by the layered metals. High and low spindle speed will just vary the vibration frequency and not something I can eliminate.
I do appreciate the suggestion and thought gone into it though, cheers
How do you do your SPT? Top slide set to 1/2 thread angle?
Carbide or HSS?
I think stress during threading generates forces much bigger than the centrifugal ones (a quick calculation gives me < 50 g @2000rpm for a 20mm tube, not THAT much) so I’d try to minimize those.
And even thermal expansion might be able to generate enough force to open that crack if it’s a weak bond to begin with.
Yes, threading does likely generate more force than centrifugal. The parting off tool generates even more force than threading. However I don’t think either of those had much effect when I had it mounted in the mandrel. The mandrel was a tight fit even without the chuck clamping down on it.
That’s an interesting concept but why such low temperatures? As far as I’m aware layered metals are forged at a little below melting point. Melting point of copper is over 1000 celsius and even more for nickel.
Have no ideas how it works with such sandwich, but I think tempering is common solution for all materials that have internal tensions due manufacturing process. And yes usually it is made with temperature that is much lower than melting point. Idea is to get metall internals relaxed so they wouldnt like to change their position after each small bump.
Also, using coolant is very recommended.
Another way - avoid all forced machining operations. Drilling, turning etc. Use angle grinder with cutting disc instead of parting tool. Sanding paper instead of skim cut. Rotary tool with mill in toolpost for internal pockets and threads.
As illustrated here, this reduces radial stress a lot:
Have you tried HSS? General purpose carbide tooling tends to have some intentional cutting edge radius, this is okay for steel and high speeds but since both Cu and Ni work harden like crazy I’d go with the sharpest tooling possible, plus both Cu and Ni need a sufficiently positive rake angle* (>15°) so hand-ground HSS tooling might work better that GP carbide.
*The internal inserts are 15° positive I think which might be enough, but I’m not so sure about edge sharpness.
And what Kirill says is worth consideration, although grinding away copper will gum up any disc pretty fast and I’m not sure how I’d tackle milling an internal thread with a rotary tool in the toolpost, that would be hell to set up.
But… if you have some liberties with thread shape etc there’s a way I’m sure.
Aah yes, the ‘relaxing’ of metals. I think I read about that once but forgot all about it. I will think about how to do that without using the kitchen oven (the missus will have a fit).
I’ve never tried that threading method though I have seen it before too. Lots of advice there, cheers
It seems i’m back on that steep learning curve. Thanks for the help guys
Well, the “relaxing of the metal” aka “annealing” is done a lot differently for different metals. Steel is done like Kirill suggested above. But IIRC, Copper is annealed in a quench, which ironically is how steel gets hardened. Just heat cycling Copper doesn’t soften it. For other metals, it might be another method. So, you need to know exactly what’s in your Mokume-gane blend, and search for annealing process for that specific blend. It may be that the two metals in your bar are enough different in how they are annealed that effectively annealing the bar is impossible. Hopefully not.
I also stumbled upon the fact that Ni irreversibly forms very brittle compounds with sulfur at higher temperatures. If you plan on heating those pieces for annealing or stress relieving and are unsure whether there’s microscopic cracks, you might want to check if your cutting oil has high sulfur content (many GP cutting oils for steel do). Once it’s in such a crack, it’s probably in there for good.
Now that I’ve finished DavidEF’s build I can work on this again. Tadaah -
It still needs a bit of clean up and I can’t do much about the cracks on the front of the bezel but I reckon I can salvage this now The ti rings are press fit with epoxy. While I was waiting for the epoxy to cure I played around with one of the excess bezels for a different finish. I first put in on the wire wheel (on the bench grinder) then rigged up a vibration container half filled with broken glass and left the part in there for about 20 minutes. I’m curious to see how it looks when the copper patina’s up. I will not be doing this finish to the above light.
Unfortunately the front end (where the split was forming each time I cut off a piece for a bezel) just … kept… on………splitting It gives me some idea that it was the pressure from the chuck that caused this.
So I had to fit another hoop to the body.
At this stage I’m expecting this split to run from head to tail by the time I’m finished I can’t not make the light now. I feel like it’s a mental battle with myself much like a marathon runner who just wants to give up but can’t on principle
I cut some small threads for the driver retaining ring. 0.5mm the smallest I’ve done to date
Also made a retainer for the tail switch
I’ve been kinda busy of late so this build is going slow. I am also trying not to jump into the next move too fast for fear of messing it up even more.
