with a bit smaller total diameter spring a back side with 7 AMCs would be no problem
Lexel, do you/could you offer a replacement D4 driver board like that? If so, I’m very, very interested, both for the original D4 and this new variant.
Seriously, get 7 AMCs and Anduril on this thing and it’ll be a de-facto FW3A killer for anybody who doesn’t have a strong dislike for side switches.
I’d like to see a 21700 optional battery tube.
The stock battery tube on the D4 is quite thick. I think there is room to bore it out for a larger cell without increasing the external dimensions of the light.
I must agree, a 21700 D4 would be awesome. On the other hand, I always wanted the D4 to be a little bit slimmer, close to the level of the FW3A and ZL SC64. 18350 tubes are perfect for impressing people too.
This looks like a better option than the (apparently?) cheapened FW3A SST-20 I ordered last week. I’ll definitely be picking this up when it releases. I appreciate seeing a product improve and not regress in quality!
Yep.
Will be picking this one up quickly if it comes with a 3x7135+FET driver, or even better, the famous Anduril 1+7x7135+FET driver.
Sooo much want.
Anduril UI and AUX LEDS? Both upgrades I wanted but could not do myself on my D4. I’m getting one when they come out!
The D4 is currently sold out on Intl-Outdoor. The D1S is also sold out. Surely this is just a coincidence, but I’m a bit giddy right now…
I don’t own a D4, but if it’s like the D1S (which I do own), Hank likes to keep things tightly packed (as shown below, source). A smaller spring would probably need to be something like one of Blue’s smaller BeCu springs or the tiny one from the Qlite drivers.
I heard someone who ordered a D4 recently got one with programming pads. If I had to guess that was probably the new driver meant for this light. If that’s the case you can probably rule out 3 channel FET.
photo from above thread:
That + a recessed button (to reduce pocket activations), and my planned FW3A order (which I’m holding on due to the glass screwup) become D4v2 orders instead.
The “recessed button” in the first post just looks like the current D4 button to me. Might be wise to wait for more info before getting your hopes up.
This looks like a good replacement for the FW3A I never got because it was lost in shipping… It’s going to be nice with the features from the D4S but slimmer and easier to fit in a pocket. A 21700 tube would be nice too if it can be made to work.
If it is not recessed that would suck.
However, I will still get it since I want the knurled body tube. I can and have made recessed buttons for my other D4s and could do that for the v2 if necessary.
Aside from the flatulent haha price of a double C-note, what does the V2 offer
That improves on the OG?
& who is gonna stock these gems, my FAS is growing.
The stock tube is thick on the D4 for a reason. It provides better heat sinking. To make a 21700 tube by boring out the 18.650 tube might work,but at the expense of heat handling. That’s not something I would want, especially with a higher capacity battery. It would mean the light would run hotter on high output, forcing you or the light to step brightness down. On the other hand, with a thick wall tube you can run the light on high longer, while gaining the longer run time advantage of the 21700 cell.
I’m not sure this is a bad thing. The tightly packed 7135s on the visible side of the FW3A driver leave them vulnerable to damage or shorts, force them to use a smaller spring, and don’t leave room for a programming header. There’s no obvious choice here.
