the optic is 1.5mm thicker than it needs to be. I highly doubt that is equivalent to a Carclo with “no lens” and besides you only get 1 flavor in this optic. They might as well add 1.5mm more shelf or make the light shorter than use this afterthought.
edit; you are just playing devil’s advocate since you yourself dont even believe what you say. I’m going to stop this.
Agreed…. :+1:
Lumintop needs to drop this silly idea/plan and get back to the basics of Carclo optic & AR coated lens in the FW3A. Otherwise, Lumintop may well alienate a lot of people. Just my opinion on the ’alienation’…… time will tell on that one. .
Yep reduced optic to 23mm diameter, you also have to champher or reduce the hieght of the mid section (light engine) to fit/clear the bottom of the optic…so it seats fully into the board.
Hello helooooo. I got my fw3a dismantled as I'm trying to do a firmware flash to toykeepers firmware for a 219b build. I'm running into an issue understanding the ping layout on the usbasp up to the SOIC clamp. I suspect it's this reason why I keep getting an error "target doesnt answer. 1" How do I repin the SOIC so it matches what's in the usbasp and for a tiny85 chip?
You could get some dupont connectors and put them between the programmer and the SOIC ribbon cable. this would allow you to reconfigure however you need. You may even be able to replace the ribbon on the SOIC with the dupont connectors.
Alternatively, if you have some solid core wire of the right diameter, you could use that instead of purchasing the dupont connectors.
If you can get the ribbon off the SOIC without breaking it, you could reattach the ribbon in the correct configuration (maybe solder it?).
Probably took too thick wires for the aux LED on prtototype
on first assebly I had the driver twisted to align to the heads cutout and ripped the pad where the optical nerve was off
so disassemble again, looks messy with the heat paste all around
Prototype, got a small bug, but can be used without the LVP chip, the bridge pads were designed on it so no big deal
but the fab let me down not cutting out the 20mm boards from the panel, so I got ordered new ones
Also made a quick thermal test, that thing gets hot fast
if you flash driver and remove the optical nerve resistor you can solder there the Aux supply
then flash a firmware variant that supports the Aux LED option
