Is there a pocket clip included?
I don’t see an option to add one on the product page.
One impulse buy on your way Hank.
Thanks for catching that — wrong image. Corrected. I’m assuming there must be some kind of RGB LED and that by balancing the ratios each of the colors can be created. Unless there’s a different kind of multi-color SMD LED available with more than RGB?
Why no white AUX-lights?
Oops, just added the “pocket clip” option
[Excited screaming]
I bought one with all the accessories immediately. No regrets.
I missed the pocket clip option but wish to add it to the order if possible?
It looks sweet
If I were to order, it would be $60 for all the extras I want :P
I think I'm going to wait and see if better colors come out, though.
Hank, it's nice to see you continue to innovate. I like what you're doing.
It looks like the switch is more recessed than on the D4v1. I await your reviews!
What is the difference between SST20 and XPL-HI?
And also between the 10622 and 10623 Carclo optics?
Thank you.
Awesome! I want to buy it!
Will a warm white be available?
Will there be an Aux LED rainbow option? multi colored?
One of the options is Warm White - SST20 3000K 95CRI.
Will the 18350 tube from a D4v1 fit on the D4v2?
I’m confused by the pictures. They show with and without stainless bezel?
The stainless bezel is an option
Just answering a few questions really quick…
… but I’ll post a lot more details soon in a review.
If I understand correctly, it ships with a revision from 2019-06-17. Like, two days ago. I spent the weekend fine-tuning the thermal regulation. The D4 is difficult to regulate since it has so much power in such a small space!
Wil the Ramping IOS V2 be there as a optional choice? Not everyone likes Anduril.
No, RampingIOS V2 has not been ported to the new driver.
It should be relatively easy to port RampingIOS V3, but it hasn’t been done yet either.
Regardless, most basics in Anduril are the same. It even has compile-time options now to change the on/off timing, since that was something a lot of people have strong feelings about.
do these lights actually have muggle mode or no?
Yes. It was removed for a while, but people wanted it back… and with a light as hot as the D4, I can understand why. So it has muggle mode now.
- 6 clicks: enter/exit muggle mode
- 7 clicks: change aux LED brightness
- 7 clicks (but hold last click): change aux LED color
Yes. One of the colors is “rainbow”. Another color is “voltage”, to indicate the battery status.
Wow, sounds fantastic. Thanks for the info TK!
My 219C D4v1’s 18350 tube won’t even fit on my XP-L HI D4v1…
That is a good question, though from my experience I have found Anduril to operate just like Ramping IOS V2 if you only use the relevant button presses.
I have found the simple shortcut to directly ramp down instead of having to guess the ramp direction to be an incredibly useful addition in Anduril however.
What is the short cut to directly ramp down?
You mean like a slow color shift around the color wheel rainbow? A continuous color rotation like that would be both weird and cool.
