Emisar D3AA is available now
[Excited screaming]
I bought one with all the accessories immediately. No regrets.
I missed the pocket clip option but wish to add it to the order if possible?
It looks sweet :slight_smile:
If I were to order, it would be $60 for all the extras I want :P
I think I'm going to wait and see if better colors come out, though.
Hank, it's nice to see you continue to innovate. I like what you're doing.
It looks like the switch is more recessed than on the D4v1. I await your reviews!
What is the difference between SST20 and XPL-HI?
And also between the 10622 and 10623 Carclo optics?
Thank you.
Awesome! I want to buy it!
Will a warm white be available?
Will there be an Aux LED rainbow option? multi colored?
One of the options is Warm White - SST20 3000K 95CRI.
Will the 18350 tube from a D4v1 fit on the D4v2?
I’m confused by the pictures. They show with and without stainless bezel?
The stainless bezel is an option
Just answering a few questions really quick…
… but I’ll post a lot more details soon in a review.
If I understand correctly, it ships with a revision from 2019-06-17. Like, two days ago. I spent the weekend fine-tuning the thermal regulation. The D4 is difficult to regulate since it has so much power in such a small space!
No, RampingIOS V2 has not been ported to the new driver.
It should be relatively easy to port RampingIOS V3, but it hasn’t been done yet either.
Regardless, most basics in Anduril are the same. It even has compile-time options now to change the on/off timing, since that was something a lot of people have strong feelings about.
Yes. It was removed for a while, but people wanted it back… and with a light as hot as the D4, I can understand why. So it has muggle mode now.
  • 6 clicks: enter/exit muggle mode
  • 7 clicks: change aux LED brightness
  • 7 clicks (but hold last click): change aux LED color
Yes. One of the colors is “rainbow”. Another color is “voltage”, to indicate the battery status.
Wow, sounds fantastic. Thanks for the info TK!
My 219C D4v1’s 18350 tube won’t even fit on my XP-L HI D4v1…
What is the short cut to directly ramp down?
You mean like a slow color shift around the color wheel rainbow? A continuous color rotation like that would be both weird and cool.
Click, click and hold it. Do a double click but don’t let go of the button at the end until you want to stop ramping down. It’s the same as ramping up, except with a quick click before you hold the button.
Ouch, I put together an order and it came to $57 and it was with the SST-20 version, 18350 and 18500 tubes as well as the SS bezel. May be a couple of weeks before I can order one of these. I really don’t use these types of lights much but they make for a great collectable.
Order placed. Will be replacing my D4V1 as my EDC.
Anyone know if this new anodizing is smooth or the rough texture?
Well…just several colors…Lexel had some boards with like green/pink/ and blue…or whatever
Pictures of the rainbow LED option and voltage LED option would be nice…
TK’s Anduril on D4S “breathes”…so a breathing rainbow would be neato!
Thank you!
