… but I’ll post a lot more details soon in a review.
If I understand correctly, it ships with a revision from 2019-06-17. Like, two days ago. I spent the weekend fine-tuning the thermal regulation. The D4 is difficult to regulate since it has so much power in such a small space!
No, RampingIOS V2 has not been ported to the new driver.
It should be relatively easy to port RampingIOS V3, but it hasn’t been done yet either.
Regardless, most basics in Anduril are the same. It even has compile-time options now to change the on/off timing, since that was something a lot of people have strong feelings about.
Yes. It was removed for a while, but people wanted it back… and with a light as hot as the D4, I can understand why. So it has muggle mode now.
6 clicks: enter/exit muggle mode
7 clicks: change aux LED brightness
7 clicks (but hold last click): change aux LED color
Yes. One of the colors is “rainbow”. Another color is “voltage”, to indicate the battery status.
Click, click and hold it. Do a double click but don’t let go of the button at the end until you want to stop ramping down. It’s the same as ramping up, except with a quick click before you hold the button.
Ouch, I put together an order and it came to $57 and it was with the SST-20 version, 18350 and 18500 tubes as well as the SS bezel. May be a couple of weeks before I can order one of these. I really don’t use these types of lights much but they make for a great collectable.
Ohhhh…maybe I misunderstood…ALL of those colors will be on the board and are selectable? As well as a “rainbow” and “voltage” mode using the multi colors?
Well… I ordered two! Dark grey with SST20 5000K and dark grey with SST20 4000K and two stainless steel bezels. My D4S and D18 have the 4000K and I really like the throw/tint.
One question… How does the voltage aux light readout work? What do I see when I configure the aux LEDs to the voltage setting? Cheers.
