Order placed, thanks Freeme!
Interested
U guys are way under. 5k+ - this should/hope will be a blf driver, fet based. I get 7k+.
Should be a TA design driver, so I would expect high oerf FET.
Astrolux FT03 XHP50.2 4300lm 735m NarsilM v1.3 USB-C Rechargeable 2A 26650 21700 18650 LED Flashlight - 5700K
Definitely interested in one of these!
Shared.
Interested
Interested
Preorder (#19) placed.
Thanks!
Coupon please!
Order placed.
Thank you for your efforts freeme.
Ordered one.
Received mine today nine days after ordering - and it looks very promising, looking forward to walking my dog tonight!
Ordered, thanks Freeme
Interested as well!
Interested!
Eleziel: mattadores:Based on the Convoy L6 70.2 smooth reflector is it safe to assume the FT03 70.2 should be around 2200-2400 lumens with 400-500 meters of throw?
I’m also assuming we’re looking at an extremely fast turbo step down due to the very small amount of heat sinking/thermal mass?
The SST-40 already does that amount of lumens with significantly more throw than the XHP70.2 would have so that would be rather pointless.
I’m guessing 3800-4200 lumen, which again is kinda pointless unless you want a larger hotspot in my opinion since the 3v XHP50.2 can reach the same output with the original driver and will have more throw due to being a smaller emitter.
Tom E:U guys are way under. 5k+ - this should/hope will be a blf driver, fet based. I get 7k+.
Tom did later say he was off in his prediction.
See my response above… Had a senior moment, an ooops, brain fart ………
With the 50.2, 21700 or 26650?
It uses a 26650. Is that what your asking?
If your asking if a 21700 fits, it does. As long as it’s not protected.
Are there any differences in the driver compared to CСT-40?
Just curious, the Convoy M3 with XHP70.2 is rated at 4300 lumens. Many compact sized flashlights with XHP70.2 have something like 3500-4000 lumens only.
Does the 3v XHP50.2 really go up to 4300 lumens? How many Amps will it need to pull to reach that 4300 lumens?
Also, 5700K and 6500K tints for XHP50.2 = I wonder if they will have the same characteristic of cool hotspot and warmer corona (although the reflector head of the FT03 is big, so it may not be that noticeable for this size flashlight?)
Thanks freeme
Just ordered mine
