Tint is almost as bad as some white CREEs
“almost”
Rebel Lime... For a second I thought it was a joke for how the oldgood XPG2s look with a wavien collar and FET.
It's, uh, a color of LED I've only witnessed within the bands of the Cree Fried Egg.
djozz
Thanks! But i have one Rebel Lime and one Rebel Alu Sinkpad left here.
I never thought that it would be such a pain to center this led. Even when the dome is right in the center you get a beamprofile that looks not centered. Only thing that helped was to tilt the reflector a tiny bit. This way you get a good looking hotspot. But still some artifacts arround the hotspot.
Next led i want to build a light with is the KP CSLNM1 F1. The Led4Power 6A driver is ordered (will turn it down to ~5A) and i can not wait to see how it looks in the D80 or the Cometa.
But i am really interested in a deep red led with high output.
Has anyone had trouble with blowing an SST-40? I’ve been messing with TIR lenses in an 18350 S2+ and it lasted about 3 seconds on the highest level. I was using a FET driver but thought I would be OK without a bypassed spring and the Efest 18350. Regardless of mode the led will only come on as if it’s in a moonlight mode.
I thought Astrolux was using a FET in one of their SST-40 lights? Maybe I just got a bad one?
There's a few possibilities. You could have damaged something in the current path, like an unbypassed spring or a switch that wasn't up to the current, in a way that increased the resistance a lot. You may have blown the SST-40, as they can only handle about 9A max... however, I don't think it's likely, as my recollection is that they burn bond wires and die completely. There could also be something wrong with the driver, but I wouldn't know what or how to troubleshoot it. With TIRs, there's no chance you shorted to the reflector, so I'm not sure what else could have happened to it. I'd also check the battery voltage and the thermal paste under the MCPCB just to be thorough.
More likely a problem with the driver or a bad reflow.
Thanks for the input. I swapped the SST-40 with an XM-L2 and all is well. I didn’t change anything else. It has me puzzled.
I would reflow the SST40 and try again. Chances are that you didn’t have a good enough thermal path and the emitter got toasty
I burned a couple of SST-40’s a while back when I upgraded to dual BlueSwordM BeCu Gen 2 springs in the tail of a Sofirn Q8 and used 30Q’s to power them through the stock FET driver. One burned out really badly and filled the reflector/lens with smoke. The other just burned a little and had permanently reduced output after. Ironically, I was trying to calibrate the Thermal Protection in Narsil, so the light was in full blast Turbo mode, waiting for me to save it from the blistering heat with a simple button push that didn’t come in time.
Can you guys recommend me a razor (or other) blade for de-doming? The crappy ones i’m using need an overhaul and I have a lot of LH351D 5000K 90CRI left
No Wilkinson specials around? Thin, flexible, just put a shim around the LED and slice it across like you’re in a deli slicing boloney.
Yeh, nice and bendy.
In case it helps:
Ha! And a Wilkinson blade, too.
I finally threw my CULNM1 (Boost HL, I think) in my Z1 after I burned the 1mm2 white flat I put in the first time. It's a glorious pencil-beam.
I did have to ream out a 3535 centering ring I had that fit the Z1, and unfortunately it is a white centering ring. So, there's a funny-looking pale donut around the blindingly white square I've painted on my wall. I can't wait to get it outdoors but it's too late now.
On white centering rings I always do an Al Jolson.
It took me a minute, but I think I figured it out, Al Jolson did blackface. I hadn't thought about painting/Sharpie/whatever the centering ring, but I'm not too worried about it. Every time I open the Z1, a certain O-ring tries to attack me and more importantly the underside of the lens (it got greasy once, and I took great care in cleaning it). Besides, the donut ring is humorous to me.
The thing is awesome though. I can see the beam itself through the air in the right environment (kind of like my green laser, but of course less). I know it's running at ~4.94 Amps (13x0.380A 7135) but I've been able to run it for several minutes without adverse effects. And I'm not too worried about battery life with a 5500mAh Shockli. The thing is not practical at all, it's the pencil-est beam I've yet dealt with, and for flood, well, it's burning 5A for like 900 lumens or something, I don't remember exactly the output. But it's so fun. And it fits in a coat pocket, unlike my MF02 (though I'm sure the MF02 out-throws it). I want to take it downtown at night and paint squares on buildings :D
I've got a second one, so now I'm seriously considering modding the MF02. If I got the focus right, it would be disgusting. I'd need a new driver, though...
