Review: UltraFire K10 (1 mode and 6 mode)
Reviewer's Overall Rating: ★★★★
Summary:
Battery:
AA/14500
Switch:
Reverse (tailcap)
Modes: 1 or 6
LED Type:
Cree xp-g R5
Lens:
Coated glass lens
Tailstands: Yes
Price Payed: 15.50 / 16.40 USD
Date Ordered: December 2010
Pros:
  • One of the brightests AA sized lights
  • XP-G R5 LED (only a few AA lights with this LED)
  • 3 very usable modes + 3 not very usable epileptic modes
  • Cheapest AA light with XPG-R5 LED
  • Very robust, durable body + good and reliable switch
  • Works with AA and 14500 without any issue (not as the S10) Some reports of lights destroyed with 14500.... put a 14500 at your own risk. However, both of mine are working perfectly with AA/14500
Cons:
  • Memory mode does not work properly
  • Lacks clip (important for me)
  • No o-ring behind frontal glass lens
  • Single mode required some "repairs" and still not powerfull than the 6 mode
  • Only available in black color
Features / Value: ★★★★
I was thinking into purchasing the TrustFire R5-A3 which is one of the few AA sized lights with XPG-R5, but finally I didnt because of the lack of LOW mode. Then on December, this model appeared, announcing 6 modes (3 usable ones = H M L). I couldnt resist.
As said, I purchased the single mode http://www.dealextreme.com/details.dx/sku.50123~r.43033281 at 15.50 USD and the 6 mode version http://www.dealextreme.com/details.dx/sku.50122~r.43033281 at a very adecuate price of 16.40 USD (cheaper than R5-A3).
I will not review all the flashlight itself because the UltraFire K10 is the same flashlight as the UniqueFire S10 reviewed by brted (https://budgetlightforum.com/t/-/142), but this time with different LED and probably circuitry (I dont have the S10 so I can not tell if the driver is the same). I will center my review only on the new characteristics added by the new LED.
Finally, after testing, I will keep the 6 mode version into my personal collection and gift the single mode to my brother (I dont like single mode flashlights except rare exceptions as the UniqueFire AA-S1).
Build Quality: ★★★☆☆
OK, I give only 3 stars in build quality because the single mode required "repairs". When arrived, I inserted a 14500 and what I saw was dissapointing. It was about 120 lumens (with 14500!!!), only drawed 0,9A or so, and the beam was not focused at all. Also some flickering.... Very bad.
Then I cleaned the threads, made new solders on the joint of the driver with the pill, thightened all and now it draws about 1,2A from a fresh 14500. Also thightening the pill to the max, the beam is better focused. But still the single mode is not as good and powerfull as the 6 mode version (dont know why).
The multimode version arrived in perfect conditions.
Also another drawback is the lack of o-ring behind the lens on both versions. However both versions came clean but unlubed.
Despite the problem with the single mode, the K10 is a good flashlight, with robust body and general good build quality. However, we have to remember what happens with the cheapo chinese flashlights (QC control almost inexistent).
Battery Life: ★★★
Well. Lets talk about 14500 usage.
The single mode (my unit) draws less current than the 6 mode, resulting in higher runtimes. I dont allow the batteries to go less than 3,6 volt as usual. So runtimes up to 3,6 volt:
Single Mode = 41 minutes (1,2A draw)
Multimode = 32 minutes (high 1,38A) - 57 minutes (med 0,9A) - Not measured runtime on low, but with 0,2A of draw it should run for almost 4 hours if not more.
Now about Ni-Mh. I only have good quality ones but only 1250mAh capacity. With such a low capacity runtimes are not interesting but, current draw of both versions is the same (1,8A). With that comsumption, you can calculate taking into account your Ni-Mh ones.
Light Output: ★★★★★
I have to post pictures here.
Mixed feelings.
MULTIMODE version -> No complaints. Produces a big hotspot with a cool white tint. Is floody but not as floody as the UniqueFire AA-S1, which is for me the holy grail.... The throw, of course, better than the AA-S1 but not throws as far as the XP-E or XR-E lights.
HIGH = about 300 lumens
MED = about 230 lumens (could be lower... about 120 lumens, but OK)
LOW = about 10-20 lumens
SINGLE MODE version -> after repearing, and trying to improve it, I managed to semi-focus the beam, but still is not focused at all and has some greenish tint... (probably only my unit... probably all the single mode... who knows... lacks of QC control)
No detected any power loss due to heat during the tests (seems well heatsinked)
Summary: ★★★★
Despite what happens to the single mode version, the K10 produces a HUGE amount of light for an AA sized light. I have compared it to a 501B with an R5, and "by eye" they have similar lumens, but with different sizes of hotspot, spill, throw, etc... (due to different diammenter and deep of the reflector).
It could be one of the greatest flashlights if it were Turbo, High, Med, Low, Very low, Strobe. And ALSO (is my opinion) they could have removed the frontal "dents". ¿why chinese manufacturers dont learn from theirs errors?
Also my opinion: when will be available an Akoray K-106 body style with xpg-R5 LED? is too difficult to the chinese manufacturers to make a flashlight with that lovely body with xpg-R5 and 5 INTERESTING modes?
I already ordered the 6 mode K10 after you gave your thoughts on your first impression!! I'm glad you like your 6 mode light! I hope all the K10's shipped draw good current.
As far as the slow memory i'm sure my instructions posted about the slow memory on the UltraFire C3SS will apply to most light's that need to be off for a long time for memory to kick in. When I get my K10 I will take pics of exactly how to fix mode memory on it.
OK; finished but pending photos.... arggg what happens to me with the photos??¿¿??¿
Glad to see a review of this one. Despite the funky mode memory, this might be one of the best R5 AA lights out there.
Here's how to do pictures:
http://budgetlightforum.cz.cc/node/14
argg impossible. I fellow the instructions but I dont know what happens
Dont forget the Ultrafire C3 R5. Same size. 1xAA or 1x14500. Extremely bright and DX have an
extensiontube for use with 2x1.5AA http://budgetlightforum.cz.cc/node/718
Hi Fran, I fixed the image and the link for you. Let me know if you need help to load a different image of your preference. Very nice review! This is an important review for potential buyers, since it's a new model with the usual incorrect description at DealExtreme.
Thanks sb, however I still havent took photos. The photo posted by me was he DX one
OK, is the stock DX photo good for now until you take photos?
Attempt nº1 to post a photo (bad quality, still no digital camera)
http://img217.imageshack.us/img217/3783/dsc00478tc.jpg
[URL=http://img217.imageshack.us/i/dsc00478tc.jpg/][IMG]http://img217.imageshack.us/img217/3783/dsc00478tc.jpg[/IMG][/URL]
Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL]
--------EDIT by sb56637-------
Hi Fran,
I edited your last post so you can see how I added the image. Just click on the image, and then click on the 18th button from the left on the top row to see the image link settings.
Take care!
Thanks sb, I dont know what happens to me and the photos.... (que patoso soy)
Si los reyes magos no me traen una camara estamos apañaos
Tranquilo, yo igual he estado pataleando con mi cámara digital de antaño, por eso nunca incluía fotos adecuadas en mis reviews. Pero acabo de comprar un celular usado con Android que trae una cámara mucho mejor que la chatarra que usaba antes.
Jaja my problem is a "mix": very bad mobile phone camera, not know how to take photos in a good way, and finally dont know how to post them (but now solved)...
Let´s see if the "reyes magos" dont bring me "carbón"
Hmm... looks like the emitter is slightly off center Or it's because of the smooth reflector?
LOL, fran I hope they'll bring you a good digitan camera ('coz I'm in the same situation LOL)
As to posting images in your posts... very easy. Just copy the URL ( http://img217.imageshack.us/img217/3783/dsc00478tc.jpg ) and paste it in (click on "OK" if you don't want to add the discription)
You can also paste the URL only, the forum will add link to it automatically
P.S.: hey, admin, where are you from? Or you've used Google translator?
Looking at the images of the TrustFire R5-A3and the Ultrafire K10 they seem to have the same reflector so the hotspot would be a large blob. Lot of flood and little throw.
Hey SashiX, Spanish is my second language, I live in South America now. Was thinking about opening ForoLinternasBarratas.com or LinternasParaTacaños.com but it just didn't have the same ring to it. ;-) Just kidding. And besides Spanish is covered admirably over at ForoLinternas.com.
Why did you call it Uniquefire is it not Ultrafire?
PFFFFFF Oh My God!!!! I am stupid! yes is ULTRAfire I need to correct it
hmmm..... Forget about that photo.... I dont know what happened to the CMOS sensor..... In real life the hotspot is perfectly round, no unperfections, no central black hole............. I need a camera
