Is there any estimate of when the colored lights will be available? I must get a purple TK Special for my wife. Will the colored lights be available through Nealās Gadgets like the current versions?
Just do nealgadgetsfw3a - the āsā isnāt in neals
PM sent.
Thanks for offering the glass so I will be able to use other Carcio optics I have.
So if Iām reading this correctly, those who have ordered the FW3C donāt need to do anything because Neal isnāt shipping those out until the 10511s arrive. Is this everyone elseās understanding?
@ Glennac
That is how I read it.
Thank you, Neal, for confronting this issue head-on and offering several options for everyone!
Well said. This really should be a satisfactory solution for everyone.
Well done, Neal.
Thanks for your hard work.
Canāt wait for the new optic you are going to design, will it be a ācloneā of the original lens or should we design our own BLF optic?
They look really cool!
Hi Neal ā thanks for making this possible! Is the āblueā option actually āice blueā? Because I donāt see any other blue option on the order page and the regular blue has a rather weak glow power (only 15), while ice blue is much more decent (60). Tritium Power Chart.
Looks nice. Do you plan to have 10511 tritium optics, too?
Hi all,
Just getting caught up here. I ordered another FW3A with sst-20 back on 6/13, if I do nothing will I get option B automatically?
The wait doesnāt bother me and I donāt really understand the optics well enough to know what Iād be getting or giving up with option Aā¦
I like the idea of a very wide spot anyway, so I will be swapping the optic in the flashlight. That said, Iām not an expert modder, so unscrewing the bezel in a dust free environment is about the extent of my expertise.
A certain supplier of Carclo optics has the option on the 10508 optic for āCarclo XP-L Mod (not necesary for XPL-HI or Nichia 219) +$1.50ā Anyone know if this will be necessary for SST-20 emitters?
No, this is not for the SST-20.
This is only needed to fit the larger dome of the xp-l.
Just to be sure. If you received your light as part of the original group buy then it already has the correct optic with glass lens installed?
If you have a glass lens and a TIR behind it, you have the ācorrect opticā.
The biggest issue with the optic they decided to substitute for the Carlco was that it was a one piece solution. It didnāt come with the glass lens, and you couldnāt just swap it out for a proper Carlco unless you had that glass lens (or a suitable replacement).
I only care because I may want to swap it out eventually, and I dislike proprietary parts/software/etc where there is no measurable benefit to using them (for me anyway).
EDIT:
I realize now that you are probably talking about a light that is as yet not delivered (so you canāt just check yourself) and wondering if you are going to receive the Carlco/glass comboā¦ I can only speak for myself because I donāt know when the cutoff happened, but I received the glass/Carlco combo on my order (NW XPL) and I was a way down the list for getting the code.
It should, but if unsure; just check & see if it has a glass lens. :+1:
Edit; When did you order? If you already have it, just check & see.
If it is one you have ordered Neal cover this in his Optics Thread.. Which happens to be the OP of this thread.
