On the other hand, TIRs have more ‘creamy’ beam, that is why they are also desirable.
But as you said, this design would be even better with an OP reflector (fine/mild texture).
Even another thing, that multi emitter reflector flashlights are almost always with small reflectors for each emitter. I would also happily take one with e.g. 6 or 7 emitters, and at least 35-40 mm diameter reflector for each emitter in the flashlight head (with nearly no or just slight overlapping).
Someone asked before, and Simon doesn’t think there’s enough demand, he believes everyone just loves mode memory and can’t get enough of it. The only convoy drivers worth buying if you don’t always want memory are the biscotti drivers since they give you choices, but they only go up to 2.8a.
His new drivers are a huge step back software wise.
Yeah, on my biscottis I have memory turned off. On my Anduril/ramping firmwares it’s on, but that’s because there’s shortcuts to other modes. If it’s just on/off and change, then I always want to start at the lowest mode. Don’t want to blind myself because I either forgot to set to low the last time I used it, or to have to cycle through.
The ability to turn the mode memory off and/or having the ability to cycle backwards by doing a long click or double click would be a welcome addition to this medieval U still keeping it more then muggle friendly.
Bt, Biscotti doesn’t have immediate mode memory, or does it?
Those AAA titanium lights look nice! I’m not a big fan of the keychain attachment sticking out like that, but it probably won’t stop me from getting one.
