Received my charger today. Great charger! Love the display. Easy to learn the user interface. I’m sure I’ll get a lot of use out of it.
I am interested to see a review by someone who has the time to carefully test the ability of this charger to adequately fill NiMH cells without overcharging them. I know this will be my go-to charger for Li-ions, at least, and possibly also NiMH, if it seems to do a decent job at filling those safely, as well.
I also ordered May 31, but the tracking number that just shows the shipper is waiting to receive the item from Banggood, so it will be a surprise when it finally arrives.
For those who already received their Lii-500S charger, have you tried its NiMH Fast tester? Does that test show too much capacity for NiMH? AS HKJ revealed reviewing the old Lii-500 Review of Charger LiitoKala Engineer Lii-500
That’s not surprising, considering that is a “charge capacity” test, not a discharge test. NiMH charging is very inefficient during the last part of charging, and a lot of energy put into them is just wasted as heat. That’s normal with all NiMH cells. So, the charger has to put in a lot more charge capacity than the real capacity of the battery, in order to fully charge it.
A discharge test is the proper way to analyse cells, especially NiMH.
I agree. One of the reasons I took advantage of this deal and bought this charger, after waiting years to buy a new charger, is that the reviews of the Lii-500 showed it does not overcharge NiMH cells by continuously pumping current into them to make sure they are completely charged to capacity in every case. I would rather have a charger that errs on the side of not completely filling a cell than a charger that trickle-charges the cells to death to max out their charge capacity.
Got mine today. I don’t have time to plug it in and play with it, but I did check to see if my Rofis protected 21700 battery woud fit. Nope, no way.
My flat top Sofirn 21700 cells fit easily, but the protected 21700 is way too long. Bending the sliding tab won’t work because the cell is too long to fit inside the plastic housing, not just the charge slot.
