I think the reviews on the DN70 maxed out around 3300 lumen. Most 26650 70.2 lights exaggerate their output. Also, 3800 to 4500 lumen is a very big jump for a boost driver.
Hello my dear friends!
Today i present you 3 new deals:
-> my links take you to the shop for more Info
-> use the forms to participate or just check my dealslist
JETBEAM JET-KO02
XHP35 1800Lumens 6Modes
USB Charging 21700 EDC Flashlight
Specifications:
Emitter Type: XHP35
Peak Beam Intensity: 18225cd
Max Output: 1800Lumens
Range: 270m
Mode: Turbo, High, Middle, Low, Eco, Strobe
Lumens: 1800LM, 1060LM, 360LM, 80LM, 12LM, 1800LM
Runtime: 1h55min, 2h, 6h45min, 27h, 140h, /
Battery Configurations: 1 x 21700 Battery (Included)
Impact Resistant 2m
Waterproof: IPX-8 Waterproof
Weight: 88g
Size: 130.3mm x 27.1mm x 27.8mm (Length x Diameter x Tail Diameter)
Haikelite MT40 for $ 45.99
SST-40 7Modes 8000Lumens
High Brightness 18650 Flashlight
Specifications:
Emitter Type: SST-40
Light temperature: 5000-6500K
Max Output: 8000Lumens
Mode: Low, MediumⅠ, Medium Ⅱ, High, Ultra High, Strobe, Ultra Low
Lumens: 200LM, 1300LM, 2800LM. 4500LM, 8000LM, / , 2LM
Runtime: 30h, 12h, 300mins. 180mins, 140mins,/ , /
Battery Configurations: 4 x 18650 Battery (Not included)
Weight: 469g
Astrolux FT03 for $34.99
XHP50.2 4300lm 735m
NarsilM v1.3 USB-C Rechargeable 2A 26650 21700 18650 LED Flashlight
Specification & Features:
Emitter: one LED, cool white or neutral white , mounted on copper DTP MCPCB
Color temperature: cool white: 6000-6500K; natural white: 5700K
Flux: 4300 lumen
Intensity: 133,000cd
Range: 735 meters
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
use my CODE: MFT03X to lower the price to: US$ 34.99
Hello my dear friend!
Have you been lurking around a flashlight from banggood and been waiting for a deal to come available for long time?
So here is the chance to get a nicer price:
GET 12% OFF the whole flashlight section with the
CODE: BGTORCH
do not forget to search my page for a higher discout!
- look into M4D M4X deals if a special deal is listed
- check if your flashlight can be used with my personal 20-32% OFF code in this collection
- use the searchfield in upper right corner for other
Can you renew the Convoy L2 sand / silver code at banggood?
i ask them !
Time to say goodby and find a verdict for the acebeam X70 with its blinding 60000 Lumens.
https://youtu.be/OLPdPQUQmS4 (stills)
https://youtu.be/rJ_oy5fZ5PQ [video from different angles)
and on my regular spot
https://youtu.be/s8tFIgf-Mf4
the folomov C2 has been since its available (and still is) cheaper in my list ;)
#avoidtheclickbait
didn’t you have a code for this light for Amazon at one time? If so, is that still available or not? Thanks.
yes - but that's expired.
I can ask if I get a new if you want.
thank you yes Martin
she said it expired June, 13
when a new one is available I get the info
hallo.Imalent DM70 is also with neutral white led or just cw?thanks
i ask the owner
Hi Martin,
my Uni-T clamp meter stopped working (does not read currents anymore, or at random) so I wanted to buy a new one, but your BG code for the UNI-T UT210E gives “expired”. Is it possible to arrange a new code?
Cheers, Jos
type | brand | model =my link to use | code | price | shop |
misc | Unitech | UT210E | MUT210E | 35.99 | banggood |
this from my list?
except that is says Uni-T, not Unitech, and a different code, and the price is lower
true - the old one is expired
i found this very promising Sofirn to be sold soon (working on a deal!)
as always: the links in the pictures lead you to the shop for detailed information!
Sofirn SP10S
90 CRI LH351D 800lm
AA 14500 Pocket Light EDC
Features:
SP10S adopts LH351D LED Neutral White, with 6 modes lightness max 800LM.
SP10S gives a great light efficiency.
It memorizes the last brightness level used in the general modes when it is powered by 14500 battery. It always turns on at Low mode when it is powered by AA battery.
and these are already available via my deals list to preorder:
Weltool M7-RD (RED)2Modes USB Rechargeable
Camping Hunting LED Flashlight 18650
2Modes 156Lumens USB Rechargeable
365nm UV with FILTER
Flashlight Detection light 18650
365nm UV no FILTER
365nm UV with even beam LENS
Hi Martin, with those specialist colour led flashlights I like a mention of the leds that are used. At least with the 365nm UV version I see a LG led, probably LEUVA33W70RL00.
