Hmm. it could just be mine then.... that's no fun.. pity
Some have switches that do that, some haven ’t. I believe the first batch of FW3A’s were fine, later batches have the squeeking thing necause of a slight design change. I have one of both.
I think they may have increased the speed on the machining tools or something, to try to keep up with demand… but that means less-smooth parts. I’ve seen some buttons which weren’t so smooth, and ended up with friction or a non-flat surface. And one person posted a pic where machining patterns were visible on the aluminum parts.
It seems somewhat uncommon though. Maybe it was just one batch, or just one machinist. I don’t know.
Same here, no squeak at all. Not completely silent but very quite… nothing close to loud.
These are my first two from first batch. Two more on the way, it remains to be seen about them.
What was the “slight design change” djozz??
I missed that…… :person_facepalming: . :slight_smile:
Edit: Looks like TK answered while I was typing.
[quote=teacher]
Same here, Not completely silent but very quite… nothing close to loud.
Same with my two from the first batch, really like the switch.
Same here. Mine are great on the two I have now
I would not change a thing about them.
I sure hope so. I love mine from the first batch and I have more on the way.
No squeak at all on the switch of either of my first-run FW3As.
If yours is squeaking maybe you can fix it by disassembling the switch and apply some steel wool or fine sandpaper to smooth out the edges.
I received my FW3A today! great light. (but some how i received the Warm white version and not the SST-20 4000K)
Some questions, (as this topic is 12K posts long and would take forever to find) is there available the SST-20 4000K star with the LEDs on it to swap in) also did anyone do any amp load/draw testing using the “stepped mode” setting for each of the 7 modes on a full 30Q or VTC6 cell?
I could not do any tail cap amp draws due to not being able to turn the light on. I don’t think anyone has posted amp draws.
Someone will probably need to extend an led wire and measure there (making sure to apply pressure on the mcpcb for good heat transfer).
So noone can confirm the tint bin for the sst20?
You can measure Amp draw like this: 2800 Lumen Everyday Carry Flashlight. TLF, BLF, Luminitop FW3A - YouTube
One big lead from batt neg to external tube’s threading for the multimeter.
One smaller lead from the batt neg to the internal tube’s exposed end to simulate the switch.
I tried that, but it did not work. :weary:
I’ve got Matts video on my list to watch. Looks like his is the 3D and it pulled 12 amps in the first few seconds.
Way back in this thread, there was speculation the length of the plastic nubin(or whatever it was called) changed in the second batch to avoid accidental activation.This caused the button to depress further and rub. I don’t know if this was ever confirmed. Maybe someone with both can take a peek .
Try here: FW3A mod thread. Post yours! - #547 by KawiBoy1428
I haven't followed this thread very closely, sorry. That could definitely be the reason.
I contacted Neal and he is going to solve this!
I’m interested to hear what he says. Please let us know.
He'll send a replacement! With some other stuff.
My SST-20 shipped :slight_smile:
Did anyone get the copper version?
Any idea when the colored version will be available?
