25mm… I think there may be a few diffusers from other manufacturers that could fit. One that comes to mind is by Nitecore, with a 25.4 mm diameter. One could line the collar of the diffuser with some aluminum tape to get a snug fit.
Experiment-ing….little 0603 led’s are a PITA! Touchy little critters too…poofed a few! Actually had the little 0603’s fitted in the trit holes……
More Purple than Blue, the Green trits are about twice as Green, but the camera dislikes UV…waiting on the micro band-pass len’s now….might try the band-pass film….we’ll see….
I was wondering where the sudden bump in interest came from…
SALES PITCH INCOMING!
I have 3d printed diffusers available, in these colors:
Everything in the top row, and the last one on the bottom, are the colors I’ve printed a lot of diffusers with.
The first one on the bottom row is a clearer, darker green. It is an old spool, haven’t done anything with it for a few years, I’m going to try printing a diffuser with it tomorrow.
Second one is glow in the dark, doesn’t last that long, but it is neat when using lightning mode.
Third is opaque yellow, which works really well.
I’ve also printed the orange one thicker, that turned out well.
I think it would work well for any of the translucents.
I test fit every one on my FW3A before they get boxed up.
I have a spool of an interesting red ordered, should be arriving any time now.
Long post, I know, but it’s almost over.
If you want any diffusers, regular ones are $1.50, thicker ones are $1.75, shipping is $4 within the US.
If you have access to a 3d printer, the stl file is available here.
Also, if anyone wants other colors, this is the company I usually buy filament from, so if you see something there that you like, I’m sure we could work something out.
Okay, I ended up printing with the “Christmas tree” green, and it looks nice.
The filament needs drying, as it has absorbed moisture over the years, so that is why it has that surface finish.
A member had a problem, his light was turning on and doing funky things when he screwed the head on?
It happened 2-3 times with the XP-L HI I have and I traced it back to the nubin….well actually the rubber boot and nubin…
I modified it with a mechanical switch… no probs…
The first 3 of my lights the driver pocket had a very tight fit, zero slop, the stainless steel retainer had clearance and it was never an issue with retainer ring making contact with the signal trace?
. Then I took one of the Nichia’s apart……and found I could re-create the problem of the light turning ON simply by screwing the head back on due to the amount of slop in the driver pocket to driver board…
I champhered the back of the retaining ring to clear the signal trace…
