It took me a minute, but I think I figured it out, Al Jolson did blackface. I hadn't thought about painting/Sharpie/whatever the centering ring, but I'm not too worried about it. Every time I open the Z1, a certain O-ring tries to attack me and more importantly the underside of the lens (it got greasy once, and I took great care in cleaning it). Besides, the donut ring is humorous to me.
The thing is awesome though. I can see the beam itself through the air in the right environment (kind of like my green laser, but of course less). I know it's running at ~4.94 Amps (13x0.380A 7135) but I've been able to run it for several minutes without adverse effects. And I'm not too worried about battery life with a 5500mAh Shockli. The thing is not practical at all, it's the pencil-est beam I've yet dealt with, and for flood, well, it's burning 5A for like 900 lumens or something, I don't remember exactly the output. But it's so fun. And it fits in a coat pocket, unlike my MF02 (though I'm sure the MF02 out-throws it). I want to take it downtown at night and paint squares on buildings :D
I've got a second one, so now I'm seriously considering modding the MF02. If I got the focus right, it would be disgusting. I'd need a new driver, though...
I finally rebuilt my fw3a with sw40 219b’s. It took a while to reflash the ATtiny85 chip to toymakers andruil firmware as I had to get a better ROIC clip.
I cannot tell the difference in color between my m43 sw45k 219b and sw40. Same luscious rosey tint.
[quote=trailhunter]
Want more rosey goodness? The FW3A len’s is not the best…UCL lens on the Right
Got just over 600 lumens more in the FW4A with the UCL lens…over the Stock FW3A lens.
I’ll take a few comparison shots vs my Convoy S3 4000K Luxeon V and post it soon
It heats up a bit faster than the 7A XP-L HI’s that were in it but it’s hardly noticeable. I would probably have noticed a bigger difference if it had NW or CW emitters in stock form. The throw is about the same as the stock XP-L HI 10511 combo, but the spill is obviously not the same. So less lumens, but same throw, epic high CRI golden goodness. Great LED’s BlueSwordM!
Today i rebuilt a C8 with a 3V XHP50.2, and one of Lexel’s drivers and spring bypassed it.
but accidently dedomed it while trying to fit a gasket which should fit, but just barely did and the whole dome came off
Which was good actually, now the cree rainbow corona has gone and the tint is way better!
The built was not very neat, especially the 18 AWG wires did not fit very well with the reflector, so i had to file down the reflector. After hours of filing it still touched the wires….
I decided to add another gasket, which is not the best looking but good functioning.
now i have a roughly built hot rat-rod.
Nice, I’ve built multiple 3v xhp50.2 in c8 hosts. The 18g wire is a little tough getting those wires through but with fine tweezers, it makes it much easier.
OK…168/212…939/1102……2809/3107 stock FW3A Triple XP-L HI 1A but with a Carclo 507 from my smallest adapter which seats the FWA3 perfectly on my T/A Maukaka Tube.
But I just looked at my 3 stock len’s and all 3 are different? 2 are Purple one is Blue and one of the Purple has very little coating compared to the other…
So the 2 Purple len’s came out of my 3D GB lights and the Blue len’s came out of my XP-L HI 1A which makes sense since my 2 Nichia’s have the Blue AR lenses which are a bit better than the Purple from what I just seen.
It’s weird that the lenses have different coatings for the same light… but I’m not sure I’d normally notice, since I generally remove the AR coating from lenses. Ever since I found a reasonably quick way to do it, I’ve been un-coating all sorts of lenses.
(reasonably quick way = put a polishing cloth on a table, then rub the lens on the cloth for ~15 minutes)
