I’ll take a few comparison shots vs my Convoy S3 4000K Luxeon V and post it soon
It heats up a bit faster than the 7A XP-L HI’s that were in it but it’s hardly noticeable. I would probably have noticed a bigger difference if it had NW or CW emitters in stock form. The throw is about the same as the stock XP-L HI 10511 combo, but the spill is obviously not the same. So less lumens, but same throw, epic high CRI golden goodness. Great LED’s BlueSwordM!
Today i rebuilt a C8 with a 3V XHP50.2, and one of Lexel’s drivers and spring bypassed it.
but accidently dedomed it while trying to fit a gasket which should fit, but just barely did and the whole dome came off
Which was good actually, now the cree rainbow corona has gone and the tint is way better!
The built was not very neat, especially the 18 AWG wires did not fit very well with the reflector, so i had to file down the reflector. After hours of filing it still touched the wires….
I decided to add another gasket, which is not the best looking but good functioning.
now i have a roughly built hot rat-rod.
Nice, I’ve built multiple 3v xhp50.2 in c8 hosts. The 18g wire is a little tough getting those wires through but with fine tweezers, it makes it much easier.
OK…168/212…939/1102……2809/3107 stock FW3A Triple XP-L HI 1A but with a Carclo 507 from my smallest adapter which seats the FWA3 perfectly on my T/A Maukaka Tube.
But I just looked at my 3 stock len’s and all 3 are different? 2 are Purple one is Blue and one of the Purple has very little coating compared to the other…
So the 2 Purple len’s came out of my 3D GB lights and the Blue len’s came out of my XP-L HI 1A which makes sense since my 2 Nichia’s have the Blue AR lenses which are a bit better than the Purple from what I just seen.
It’s weird that the lenses have different coatings for the same light… but I’m not sure I’d normally notice, since I generally remove the AR coating from lenses. Ever since I found a reasonably quick way to do it, I’ve been un-coating all sorts of lenses.
(reasonably quick way = put a polishing cloth on a table, then rub the lens on the cloth for ~15 minutes)
I tried a couple types of paint thinner, nail polish remover, vinegar, laundry supplies, lens cleaner, etc… but none of it made any noticeable difference, even after soaking overnight. Eventually what worked was just rubbing the coating off.
I mic’d all 4 UCL len’s and used the (smallest) of the 4 at 22.61mm the spec is 22.61mm (+/- .127mm ) so about .0075” a side smaller, yes it sealed up, I filled the bezel with Sparkle window cleaner for about almost 2hrs, no ingress of liquid…YMMV…
Some comparison shots between the FW3A 3000K SST-20 (BlueSwordM) 10507 and a Convoy S3 4000K Luxeon V. My phone doesn’t have the best camera but I set the white balance to 4000K and the other settings were the same for both lights on all pictures.
For a friend who wanted a compact wow-thrower, and me not wanting to spend much time/money on it, I dug up a Revtronic MT20 from my flashlight junkyard. It ended up there because of the horrific low frequency PWM at low modes, the mediocre output and impossibility to swap out the driver easily.
The 20mm board was swapped for a led4power 3535 DTP board with a 1mm2 White Flat. In fact it was one of the boards still ready made with led already reflowed, surplus from the reflow comparison test that I recently did. The led has had 9 amps for a while in that test, so output/lifetime may not be optimal anymore.
It did need a little bit of adjustment: the reflector hole was reamed very minimally to 7mm diameter, then a standard XP-centerpiece did fit. The square hole in the centerpiece received (cut out with scalpel) new 3030-corners 45 degrees from the present 3535-corners (see picture). Strange enough the centerpiece did not need to be sanded thinner (which normally needs doing when going from a domed to undomed emitter), the best focus was achieved with the centerpiece at full thickness. I guess the stock XM-L2 was never focused correctly in this light.
So it was a quick under 1-hour mod and the stock Revtronic driver appears to feed the White Flat about 3.5A which should be good for about 85% of the maximum output of the White Flat. I measured 125 kcd which is respectable for a compact thrower.
So if you still have one of these lights around, or get one for 13.75 from Fasttech (FT has quite a collection of old stock btw), this is an easy host for the White Flat with a decent result. It does still have that PWM on low modes, but a thrower is not about low modes anyway.
Took my dusty old Emisar D4 today and installed one of Lexel’s FET+6+1 drivers running Anduril. I then reflowed some below BBL SST-20 3000K 90CRI LED’s (that good stuff from BlueSwordM) … If this is what the D4 was like out the box then it wouldn’t have collected so much dust. Max ramp is set to max AMC regulated current. Awesome light!
