FW3A mod thread. Post yours!
If you want a great diffuser that is snug fitting & will stay on get THESE , they are great!! They fit perfectly, stay on, and diffuse great.
They fit as they come… no adjustment or tape needs to be used. They fit perfectly.
KB posted about them… I have quoted it below. I have the same colors as in the picture. I love em’…… :slight_smile:
[/quote]
[/quote]
Thanks teacher, I sent him a PM.
Your welcome!! :+1:
I was wondering where the sudden bump in interest came from…
SALES PITCH INCOMING!
I have 3d printed diffusers available, in these colors:
Everything in the top row, and the last one on the bottom, are the colors I’ve printed a lot of diffusers with.
The first one on the bottom row is a clearer, darker green. It is an old spool, haven’t done anything with it for a few years, I’m going to try printing a diffuser with it tomorrow.
Second one is glow in the dark, doesn’t last that long, but it is neat when using lightning mode.
Third is opaque yellow, which works really well.
I’ve also printed the orange one thicker, that turned out well.
I think it would work well for any of the translucents.
I test fit every one on my FW3A before they get boxed up.
I have a spool of an interesting red ordered, should be arriving any time now.
Long post, I know, but it’s almost over.
If you want any diffusers, regular ones are $1.50, thicker ones are $1.75, shipping is $4 within the US.
If you have access to a 3d printer, the stl file is available here.
Top picture, top row, second from left…. what color is that??
I see some new colors have been added… along with a double thick Orange.
Time to order some more soon!! :+1:
Thanks for the update Minocc!! :beer:
That would be the red-ish one.
I should be getting a spool of this soon.
Also, if anyone wants other colors, this is the company I usually buy filament from, so if you see something there that you like, I’m sure we could work something out.
Ok… the “reddish one”… it looked kinda orange to me & I was just wondering. Thanks for the info.
The one below you are getting soon looks interesting…. I’ll be getting one of those for sure. :wink:
Garrett’s Chaos Red
These look pretty good too. :wink:
Sean’s Cotton Candy State Faire
Chelsey’s Powder Puff Unicorn
Okay, I ended up printing with the “Christmas tree” green, and it looks nice.
The filament needs drying, as it has absorbed moisture over the years, so that is why it has that surface finish.
I’ll start the drying process tomorrow.
That “Christmas Tree Green” looks nice.
I like how you do the ‘example pictures’ in the same room each time. That eliminates many variables. :+1:
A member had a problem, his light was turning on and doing funky things when he screwed the head on?
It happened 2-3 times with the XP-L HI I have and I traced it back to the nubin….well actually the rubber boot and nubin…
I modified it with a mechanical switch… no probs…
The first 3 of my lights the driver pocket had a very tight fit, zero slop, the stainless steel retainer had clearance and it was never an issue with retainer ring making contact with the signal trace?
. Then I took one of the Nichia’s apart……and found I could re-create the problem of the light turning ON simply by screwing the head back on due to the amount of slop in the driver pocket to driver board…
I champhered the back of the retaining ring to clear the signal trace…
That driver looks off centered. When mine was off centered like that , I had weird issues.
That’s why he champhered the retaining ring, if I read correctly…. to eliminate those weird issues.
Oh I see, makes sense. One final photo of the centering would have been good to see. I like the chamfering idea.
I dried the green, much better results.
Had to swing by the filament supplier for work, ended up getting three new colors.
Red, Aqua, and Plum Purple.
The red is not the Chaos Red that I’m still waiting on.
More pics!
The Aqua looks blue-er that this pic shows
And the Plum is quite opaque.
Experimentation is fun!
@ Minocc… Nice colors. :+1:
Which one is this?? Is it a new one?
Yeah, that is the plum purple. It looks almost UV-like, but doesn’t charge glow-in-the-dark stuff. Not that effective, but it looks cool.
That looks like the driver is probably not rotated correctly, which throws off the centering. It may have just needed to be rotated to align the flat edge.
Oh… Ok, I thought it was some kind of different Blue. It looks pretty neat.
Thanks for the info. :slight_smile:
No, it’s in the pocket, that is the problem (with this one) the driver is too small for the pocket. This shows how much I can rotate the driver in the pocket.
I don’t suppose you can hold the driver in a centered position while tightening the retaining ring? I’ve had to do that sometimes, especially on the tail PCB. Once it’s tightened in position though, it should stay pretty well.
