This. Just watched a video on this. Distance can’t be beat. One battery. Have something else for closer and for flood.
Marc, I am not familiar with beam scatter from humidity or reflection off the sea, and how this would impact my choice in light. Is being blinded by reflection off the water a big issue with these types of normal beam spread lamps? I can imagine what you are concerned about. Are you saying that the extremely narrow beam of the laser/phosphor light would be needed to sight objects on shore at a distance between say 400 and 800 meters?
You asked……
Spotting on shoreline would mostly be between 400 and 800 meters (something up to 1,500 meters would certainly be welcome though beyond my wildest expectations)
Navigation (in good visibility) between objects would require a beam that would illuminate the area up to 400 meters with excellent detail such that we would not miss a navigation marker, and up to 200 meters such that we would not miss a 1 meter wide dark colored rock near the surface. We don’t mind having to pan the beam back and forth a bit to cover the area ahead of us.
Our primary need is the Navigational one and secondarily….we are hoping to be able to visualize objects on the shore up to at least 800 meters. We do not need to use the light at a ‘pointer’
Does this help answer your question?
I was using my BLF Q8 (reflector light) on a white bay boat at night and the reflection from the boat was terrible. The more I cranked the light up to see further the more blinded I would get from reflection off the boat. A fixed aspheric light would be good but I have no suggestions outside of a modified one.
Granted this boat I was on I am sunk down in the hull having to hold the light in my hands. Your situation may be different if you have a raised platform or something to use.
U want reliability?? Then choose malkoff! USA made fully potted. I don't recommend thrunite
https://malkoffdevices.com/collections/large-malkoff-led-flashlights/products/malkoff-hound-dog-super-flashlight?variant=32257906371
I would be standing on deck holding the light above my head (I’m 6’6” tall) probably at the bow while the crew steers. So reflection from the boat itself would be minimal.
If you want a traditional flashlight that would be a bit more versatile and less money I would suggest this one:
The upper end of your range (800 meters) will be pushing it with that light.
If you want an even larger/heavier traditional light:
And finally the laser phosphor option suggested above if you want a true pencil beam. Lots of warnings about shining this in people’s eyes and it seems pretty niche for its uses though:
I would check out the Olight Javelot Pro Javelot Pro Powerful Spotlight Flashlight - Olight Store Mainly because of how long the run time is. It does have enough throw. 1080 meters
LIGHTING LEVELS
LEVEL 1 (lumens) 2100
Run-time LEVEL 1 2100 lumens (~1000lm); 10 mins/ 130 mins
LEVEL 2 (lumens) 600
Run-time LEVEL 2 5hours.
LEVEL 3 (lumens) 150
Run-time LEVEL 3 23hours.
LEVEL 4 (lumens) 15
Run-time LEVEL 4 8days.
Yes but they can’t throw 800 meters…
1080 is the theoretical throw, you can guess half of that of usable throw.
+1
Is it dangerous to sail around the world?
What about encountering pirates ?
You won’t be illuminating objects on a distant shore with it, but if I were headed into that sort of environment I would absolutely have an HDS with me. Rock solid, super reliable, built to take a beating in all sorts of environments. The guy who makes them is a caver and built a flashlight he can trust his life to. I’d probably want something else too, something larger and more powerful, but the HDS would definitely be with me too.
I'd rather encounter those than pirates!
Oops
Auto corrections on phone hahah
After al suggestions above I still think you would be most happy with a thrunite tn40 or 42 and maybe the C version if you want to charge in your light.
The lep lights have a far to narrow beam. You will be waving it around like a lightsaber to see something.
Adhara,
How is the tint on the Maxtoch with no filter? Is it as blue/ saber like as the W30? (I love the saber look, yet my eyes choose warm > neutral > cool every time). Any difference in diameter/size of beam? The distances we are talking about are so far anyway, I don’t believe a small difference in throw would make any impact on my buying decision, unless that difference is significant. I love the W10 CRI beam tint posted in another thread…looks so nice! Now seeing the W30 is out there in high CRI, the tint feels like it could be the deciding factor. I am also seeing a premium for the CRI edition, narrowing the cost gap between the Xsword and W30 CRI. I’m interested in your take.
Thank you kind sir!
Joe
On the plus side, you could make the “fwooom fwooom” sound effects while doing that…
Still, “two is one, one is none”, especially out on the ol’ briny, so I’d get a WEP for looooong-distance throwing, a pair of big zoomies (Cometas/Z1s, Brynites, etc.) for medium distance throwing, and even a big honkin’ Q8 for closer more general-purpose use.
Could you clarify this? The Maxtoch web page Contactcr linked to says the light has an LED, not LEP, with 1900m throw. The Acebeam claims 2400m throw. Which model Maxtoch do you have, is it different from the linked one?
