I watched your video on youtube. Great review as always. I like how you show what the light looks light being shot back at the camera from a distance. Pretty crazy. Makes me think of this video I saw of a cop shining his light in a guys face. The cop was being rude for no reason. The guy then took out a much more powerful flashlight and shined the cop in the face. The cop backed off and put his flashlight away. It probably would have ended differently if this light was shown in the cops face though. Its almost assault level of brightness.
Anyone know if Acebeam has shipped the high cri w30 version? I really want to see a beam shot, especially after seeing the linked w10 high cri shots, perfect tint imo. Would there be a perceived (or real) difference in throw compared to CW? Cuts atmosphere better yet appearing less intense? The light saber look of w30 beamshots Ive seen in CW are very appealing.
I know I dont need this, but damn I want one bad. Wheres best place to buy? And where when high cri is available?
Good eye jericho!! I desperately want to see a comparison of beam shots in the field, though I think my mind is made up. And they’ll squeeze me for the premium CRI charge too!
lol no prob my eye’s been on this light too… but one can only eat ramen for so many consecutive days… maybe if i wait it out a bit longer it’ll take a dip in price and i’ll snatch then :nerd_face:
No, not at all. What comes out of the front is mostly not laserlight anymore, it is phosfor fluorescence plus a bit of the original blue laser light but dispersed so harmless. In fact it is no different than a weak 450 lumen aspheric light, just extremely nicely projected in a parallel beam.
Unless something breaks inside and the blue laserbeam comes out of alignment and escapes through the lens. But I assume that the construction is such that that does not happen easily.
My understanding is the LEP module works like this:
blue laser diode projects laser beam forward.
laser beam passes through phosphor material. Phosphor scatters some of the blue light, plus emits red and green. Result is a very intense point source of white light. This white light is not coherent, so is much less dangerous than the original laser beam.
An aspheric lens captures this white light and focuses it out the front in exactly the same way that an aspheric lens LED light works.
A small portion of the original blue laser light passes through the phosphor layer as a coherent beam. To remove this from the output of the light a small rectangular mirror is mounted on the back center of the lens. This mirror diverts any remaining coherent blue light 90 degrees harmlessly into the side of the bezel.
Result is no special eye protection should be needed for the use of an intact LEP light. However, the W30 is still a 1.4 million lux light, so don’t point it at someone’s face. I suppose you could blind someone if they looked into the beam long enough just as you could with a 1.4 million lux LED light.
If things go out of alignment so the beam misses the mirror or the mirror falls off the back of the lens then there might be a danger.
