The waterproofness is not effected by removing the metal switch cover. Also, the nubbin (or substitute) is required on most samples for operation when the metal cover is still installed, but once removed, it is unnecessary.
Yes. It is not as pretty looking without the metal cover, but for me, function comes first every time. I’ve never had a metal switch that I’ve liked. I hoped that the FW3A would change this, but it hasn’t.
I’ll be posting some other pics and solutions for the switch and nubbin substitution for those that care in the mod thread. But that’ll be this evening. Spoiler: replace the nubbin with a piece of 18awg Silicon wire insulation (length of your choice between ~1-2mm) and if available use a tiny tiny (that’s a very specific size lol) o-ring around the nubbin seat in the rubber switch boot. Together these provide a larger, softer contact surface to the diaphragm switch, increasing the required pressure to ‘click’ and being much more resistant to accidental activation.
I’m even stirring up some thoughts on what to do with this gap between the rubber boot and tailcap aperture… we’ll see if that gets anywhere
Yes. But without the nubbin, more central/focused force is needed. My personal light has a substitute (~1/2 height — flush with the rubber around it) nubbin and to me it’s perfect. Removing the metal part naturally recesses the switch. I think it feels great with the chamfer the FW3A has in the tailcap.
WOW, thank you for suggesting removing the metal switch cover guys. This makes the switch waaayyy harder to accidentally press and against my better judgement I think I can safely carry this light without locking it out now.
Its not just that the actuation force is higher now either, the switch with just the rubber boot sits much lower in the tail and is more shrouded from accidental clicks.
With the nubbin removed the switch still works but is even stiffer and that takes it a bit too far in that direction IMO, especially for multi-click actions.
This is exactly my experience. When pushing the light into my jean pocket (clipping in on) I’d use the ball/base of my hand to ‘seat’ it. This would result in switch activation 80% of the time if I wasn’t consciously avoiding it. All lockout solutions just became too much of a hassle to be practical. Like others have said, an A6/S2+ or other reverse clicky lights would win out due to this. I use my light probably 10-40 times a day for usually just seconds or minutes at a time. So ingress/egress and switch ergo / reliability is really a HUGE factor in a lights design.
This light still needs a deep carry clip and I need to get around to making that extended bezel for the single emitter/reflector. But right now I’m excited and relieved that two years of waiting and anticipation wasn’t wasted.
If it helps, the FW3A is designed to be compatible with a standard rubber boot. It makes the button easier to use while wearing gloves, but also harder to press by accident.
You may have to crank down the tailcap extra-hard though, to make it work. Or possibly thin out the base of the boot a little to reduce how much it needs to be squeezed to fit.
Thank you, TK! I prefer my polished to stay polished. : ) Since following this forum I have been motivated to buy the E07 (which I love) and the GT micro. I will order the FW3A soon, if I don’t find the FW3Ti posted sooner. : ) Thanks to you and all for bringing such gems to my attention!
“”Ordered one. Is the 219C really only 78% as bright at the Cree emitters? I wish I’d known.“”
Yep. I’ve got several model torchs doubled up.
It IS an obvious amount of beam density and range variation…
BUT…
Unless I’m buying an actual “thrower”, I go the 219B or C every time.
The colour rendition is soo much sweeter and more natural.
That Grey is beautiful. Also my fav colour in the different MFG’s, body’s.
Along with the Copper. Which Ï”prefer “seasoned”. Weathered.
Like me.
My O-Light i3T copper is a lovely mix of copper to brass.
with a bright, deep coppertone clip on it.
The copper prototype still has a rough surface at a very small scale, even after doing a bit of polishing. It actually tends to pull gunk off the polishing cloth so it gets stuck in the microscopic pits in the metal, so I end up having to rub that gunk out.
The new model’s polished surface should be a lot easier to maintain.
