FW3A mod thread. Post yours!
A member had a problem, his light was turning on and doing funky things when he screwed the head on?
It happened 2-3 times with the XP-L HI I have and I traced it back to the nubin….well actually the rubber boot and nubin…
I modified it with a mechanical switch… no probs…
The first 3 of my lights the driver pocket had a very tight fit, zero slop, the stainless steel retainer had clearance and it was never an issue with retainer ring making contact with the signal trace?
. Then I took one of the Nichia’s apart……and found I could re-create the problem of the light turning ON simply by screwing the head back on due to the amount of slop in the driver pocket to driver board…
I champhered the back of the retaining ring to clear the signal trace…
That driver looks off centered. When mine was off centered like that , I had weird issues.
That’s why he champhered the retaining ring, if I read correctly…. to eliminate those weird issues.
Oh I see, makes sense. One final photo of the centering would have been good to see. I like the chamfering idea.
I dried the green, much better results.
Had to swing by the filament supplier for work, ended up getting three new colors.
Red, Aqua, and Plum Purple.
The red is not the Chaos Red that I’m still waiting on.
More pics!
The Aqua looks blue-er that this pic shows
And the Plum is quite opaque.
Experimentation is fun!
@ Minocc… Nice colors. :+1:
Which one is this?? Is it a new one?
Yeah, that is the plum purple. It looks almost UV-like, but doesn’t charge glow-in-the-dark stuff. Not that effective, but it looks cool.
That looks like the driver is probably not rotated correctly, which throws off the centering. It may have just needed to be rotated to align the flat edge.
Oh… Ok, I thought it was some kind of different Blue. It looks pretty neat.
Thanks for the info. :slight_smile:
No, it’s in the pocket, that is the problem (with this one) the driver is too small for the pocket. This shows how much I can rotate the driver in the pocket.
I don’t suppose you can hold the driver in a centered position while tightening the retaining ring? I’ve had to do that sometimes, especially on the tail PCB. Once it’s tightened in position though, it should stay pretty well.
These mods are unbelievable. really creative and crafty.
Oh it’s back together, centered and working fine, trashed the nichia’s and put some NW V2’s in it and trits. The pipe fitter at work LOVES IT! Wants another…. :+1:
I just inverted the position of the rubber cap + nubin below the metal cap and it started being more silent while clicking.
It didn’t fully overcome the somewhat delayed turn OFF after clicking but it also helped on that.
that almost needs a picture, did you flip the siliconcap+nubbin?, with the nubbin now touching the metal cap?
Just to be sure, the nubbin is this small black piece of plastic, right?
!Imgur: The magic of the Internet !:Imgur: The magic of the Internet
If so, yes, that is what I did :stuck_out_tongue:
I flipped the silicon cap and the nubbin is now touching the metal cap.
I found out that, at least on mine, the curve (dome) on the silicon cap needed to be pushed down to make pressure more evenly to avoid noise due to a single pressure point.
After trying several “normal” silicon buttons, with and without the original below them, it was that solution what helped.
Later I may try to take a photo if needed, as I don’t have the FW3A with me atm!
got it, no pic needed :+1:
Nice :wink:
Later I will try to capture de sound differences in video, just in case it helps anyone :wink:
Thanks mate, I was having trouble posting images this morning :zipper_mouth_face:
But that’s what I was referring to :wink:
Still waiting on mine, hopefully get the tracking soon. :cry:
