For what you’re looking for I think your best option is to wait for the titanium FW3A. It hit’s all the bases:
copper head with rest of the light titanium
shortcut to moonlight for initial turn-on.
up to 2800 lumens output
Very small and compact for an 18650 light with a great UI.
Looks gorgeous.
It’s not out yet, but I’m keeping fingers crossed that hopefully it’s available in a month or two. Here’s one of the pictures that was posted in the FW3A thread of the prototype:
The FW3A has no built-in trit slots on the outside of the body. However, it can use a Carclo 10507 optic, and I know that Neal is selling such optics with 3 trits pre-installed for $30 each.
Some people have also modded the tailcaps in their aluminum FW3As to add room for a trit. That’s probably the only other place to put one.
If bezel trits aren’t bright enough for you, Lexel has prototyped an aux led board. When installed, you get a colorful glow behind the bezel when the light is off from 12 tiny colored LEDs. These are typically much brighter than any trit.
The copper section is the head. It’s a single piece that contains the shelf for the star (the board with the LEDs on it), and the driver.
Titanium is a relatively poor conductor of heat. It’s common for titanium hot-rod lights like this one to use copper for the section with the star on it for just this reason. Copper is an excellent conductor of heat and helps remove the heat from the LEDs.
The FW3A is quite a small light for producing around 3,000 lumens. It is 25mm wide at the head and 92mm long. It’s one of the most compact available 18650 lights.
I get that, it just looks out of place with that being the only copper part of the light. Rear tail section or possibly a copper pocket clip would make it more visually appealing to me.
That LED idea sounds cool. As long as it doesn’t run down the battery too quickly and isn’t so bright I can’t sleep at night… Do you have a link to it? How can I learn more?
There are titanium lights out there with copper heads (for heat) and matching copper tail (for looks). Here’s one of mine, a FocusWorks Eryx F1.
I also have the ReyLight Dawn already mentioned, solid titanium. Its a great light, but it does not shed heat well. In fact one fateful evening I wasn’t paying close enough attention to how hot the head was getting that it melted its own polycarb optic. Luckily its a $2 part…
That’s not to discourage you from the ReyLight, its a great flashlight. But it does require some careful handling. Its not one I’d hand to my kids…
I’m going to have a hard time justifying going much over $300, but I’m glad to see options above that.
For the FW3A, what price range should I expect?
Waiting a few months is no big deal for this purchase. I’m looking for a light that really hits everything I’m lacking in the S41S, so I’m willing to wait for that.
The price on that makes me a tad nervous. I’d expect to pay at least $150, but I won’t say no to keeping my money. Not a huge fan of the design. I’ll be watching to see what people say about reliability for this one.
Also, that FocusWorks Eryx F1 looks fantastic. A bit out of my price range. I’d take a simpler stone washed exterior to save money if possible (hoping to keep below US$300).
I found the Sunwayman C25C Ti Thrones, but it has no moonlight mode, same for the Sunwayman M25C Ti Titanium, and for the Luckysun 18650. Moonlight is my primary use.
Does anyone know of any lists I could throw my name on to so I get an early notification? As long as I can subscribe to something, I can jump on it when it comes available. Preferably, I’d join several lists to be notified of any new Ti lights. How can I do that?
There used to be an Olight S30 baton in two versions, polished and bead blasted.
Nothing revolutionary, just a very expensive 18650 tube light.
That was about the same time as the above mentioned SWM C25C was available.
EDIT: some time later, I read about a really limited edition M20 Warrior
