That looks fantastic as far as specs. I’d prefer a stone washed appearance, but that’s just me.
What do you think the trit options are?
The FW3A has no built-in trit slots on the outside of the body. However, it can use a Carclo 10507 optic, and I know that Neal is selling such optics with 3 trits pre-installed for $30 each.
Some people have also modded the tailcaps in their aluminum FW3As to add room for a trit. That’s probably the only other place to put one.
If bezel trits aren’t bright enough for you, Lexel has prototyped an aux led board. When installed, you get a colorful glow behind the bezel when the light is off from 12 tiny colored LEDs. These are typically much brighter than any trit.
The copper section is the head. It’s a single piece that contains the shelf for the star (the board with the LEDs on it), and the driver.
Titanium is a relatively poor conductor of heat. It’s common for titanium hot-rod lights like this one to use copper for the section with the star on it for just this reason. Copper is an excellent conductor of heat and helps remove the heat from the LEDs.
The FW3A is quite a small light for producing around 3,000 lumens. It is 25mm wide at the head and 92mm long. It’s one of the most compact available 18650 lights.
I get that, it just looks out of place with that being the only copper part of the light. Rear tail section or possibly a copper pocket clip would make it more visually appealing to me.
That LED idea sounds cool. As long as it doesn’t run down the battery too quickly and isn’t so bright I can’t sleep at night… Do you have a link to it? How can I learn more?
There are titanium lights out there with copper heads (for heat) and matching copper tail (for looks). Here’s one of mine, a FocusWorks Eryx F1.
I also have the ReyLight Dawn already mentioned, solid titanium. Its a great light, but it does not shed heat well. In fact one fateful evening I wasn’t paying close enough attention to how hot the head was getting that it melted its own polycarb optic. Luckily its a $2 part…
That’s not to discourage you from the ReyLight, its a great flashlight. But it does require some careful handling. Its not one I’d hand to my kids…
I’ve wanted a Dawn for a while but interested in the new Gemini coming out more.
I’m going to have a hard time justifying going much over $300, but I’m glad to see options above that.
For the FW3A, what price range should I expect?
Waiting a few months is no big deal for this purchase. I’m looking for a light that really hits everything I’m lacking in the S41S, so I’m willing to wait for that.
The price on that makes me a tad nervous. I’d expect to pay at least $150, but I won’t say no to keeping my money. Not a huge fan of the design. I’ll be watching to see what people say about reliability for this one.
I searched for this but did not find it.
Also, that FocusWorks Eryx F1 looks fantastic. A bit out of my price range. I’d take a simpler stone washed exterior to save money if possible (hoping to keep below US$300).
Sunwayman makes a titanium 18650 light, I dont own one, so I couldn’t tell you much about it. Doesn’t look like it has a moonlight though.
There’s a Reylight triple dawn on ebay also.
https://www.ebay.com/itm/ReyLight-Triple-Dawn-Titanium-Stonewashed-Cree-XPL-HI-6000K-LED-Flashlight-NEW/383024343964?
I found the Sunwayman C25C Ti Thrones, but it has no moonlight mode, same for the Sunwayman M25C Ti Titanium, and for the Luckysun 18650. Moonlight is my primary use.
I also found the https://intl-outdoor.com/emisar-d4ti-high-power-flashlight-p-927.html light recently. Looks fantastic, but no stock.
Why does it seem like the whole world is out of stock of titanium 18650 flashlights?
Because people want them lol.
Does anyone know of any lists I could throw my name on to so I get an early notification? As long as I can subscribe to something, I can jump on it when it comes available. Preferably, I’d join several lists to be notified of any new Ti lights. How can I do that?
Also, on a bit of a whim, I ordered this:
LED 18650 Flashlights - Ochoos AT40 4x Ochoos 219C/2x XP-G3 1200LM 3Modes Memory Function Convex Lens Professional Floodlight Titanium Alloy EDC Flashlight - (Design: 4x Ochoos 219C) https://www.amazon.com/dp/B07FY1MYYG/ref=cm_sw_r_cp_apa_i_SA7fDb7NG0WJZ
I’m not sure what output modes are available or what the reviews are or what the modification options are.
I also got this recommendation, but the head is a bit bulky for me. Great for another purpose (not a pocket light).
https://skylumen.com/collections/v54-lights/products/fireflies-e07vn-cu-ti-full-cu-pre-order-r
Copper is too soft without rigidity, a copper pocket clip will bend pretty easily.
There used to be an Olight S30 baton in two versions, polished and bead blasted.
Nothing revolutionary, just a very expensive 18650 tube light.
That was about the same time as the above mentioned SWM C25C was available.
EDIT: some time later, I read about a really limited edition M20 Warrior
LED 18650 Flashlights - Ochoos AT40 4x Ochoos 219C/2x XP-G3 1200LM 3Modes Memory Function Convex Lens Professional Floodlight Titanium Alloy EDC Flashlight - (Design: 4x Ochoos 219C) Amazon.com
You can search for Amutorch AT40 that is the original name of that brand. There are some reviews or at least impressions around here.
About the FireFlies they are also talked here on the forum!
I tried to find this on his site, but gave up. Do you have the direct link to this listing?
