OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
Will this led provide any benefits on a reflector like these - in terms of throw @ 2 or 3 amps ? or i’m better off going with xpl-hi instead ? these are motorcycle auxiliary spot lights and i want to increase throw with making the beam more narrow.
above one is @3 amps
^ this one is @2 amps. asking this because i can’t increase the current. and it seems like white flat requires higher current. so before ordering new leds, just want to be sure.
Wrong!
White flat will spank XP-L HI's ass at any current, and namely at 2 to 3 amps.
well that’s a good news, i was reading a thread about black flat on Emisar D1s @ 5amp and manufacturer abandoned the plan so i thought maybe it requires higher current. one more thing, can i reflow it on xm-l2 board or not. and do i need to worry about anything else ? or its just replacing the led and go kinda thing.
thanks
No, you can’t.
You need a triple 3030 MCPCB to be able to reflow them on.
The alternative to getting more throw would be dedomed SST-40s.
i have never done dedoming before so that option is a no go for me. guess i will get white flat on 16mm dct instead of reflowing on current board. leds have minimum 17mm distance between them, so i think 3x 16mm boards will be fine. now only issue left is, these leds are 6000-6500k or above, but i guess you gotta lose something to gain something.
If you have enough center to center distance go for it slopegatri70, 3 × ∅16mm boards. Just pay attention at how is the stuff set up, very likely emitters in series (3S1P).
CSLNM1.TG (1mm²) is ≈6500K that's what there is. The tint is nice, though, my recently built M1 looks pretty white to my eyes, far better than most cheapass emitters inside cheapass flashlights. But ;-) cool.
It'll be an interesting throw upgrade, for sure.
Sounds like a plan that could work :slight_smile:
Although there is some work involved, quite a bit of wiring, but the main problem to solve: you need a new way of centering those small 3030 leds: measure the reflector hole, find a source for 3030 centering pieces (intl-outdoor?) , maybe adapt the thickness of the centerpieces for best focus, and possibly ream the reflector holes to fit them.
Reflector hole is 7mm, and it seems like intl-outdoor sells 7mm gasket with white flat. yes those leds are connected in series. only thing i haven’t measured is space between reflector base and dct board, since i will need to solder some wires there to connect leds. i guess 22-20awg wire should be fine, will see.
hopefully experiment will be successful, i just want to narrow the beam and decrease the glare for inc traffic. previously i was modding BL70s with xhp35hi with aspheric lens, but beam intensity wasn’t enough so bought these lights instead.
anyway, thanks for the help guys.
I have also posted this in the L2/L6 modding thread, but this might be just the more appropriate place to ask :wink:
So i took the gamble and just ordered the L21a to build a nice thrower
Together with some high drain 21700 Shockli cells and the famous Led4Power 3030 MCPCB with OSRAM KW CSLNM1.TG and another OSRAM KW CSLPM1.TG
I am planning to keep the original driver, but still doubting which LED to use, @6A the 1mm might be just overdriven and the 2mm might be just underdriven.
What are your opinions?
I would go for the 1mm and remove the spring bypass.
If you take my test of the 2mm2 White Flat as guidance, at 6A you are at 120% of the maximum rated current and 93% of absolute maximum output, is that what you call underdriven? :open_mouth:
The 1mm2 gives less output and a bit more throw. The driver is regulated at 6A? You may want to look at the convoy store, they have a similar driver regulated at 5A if I remember well.
Ok Jos, you convinced me :wink:
I’ll try the 2mm, otherwise i can still swap in the 1mm to see the difference and burn the S*@T out of it
Since when do we play safe?
Good luck with your build :wink:
The 5000mA driver from Convoy gave me 4570mA on its highest setting while powering the 1mm white flat, so i guess it is not quite 5A driver which is perfect for the 1mm led.
Nice info, thanks! I have a few of these 5A drivers underway for this purpose so I’m happy now :slight_smile:
That is similar behaviour to that of the 17mm / 22mm driver for SST40 (weird firmware, max 8A). One of my ∅22mm units stock delivered ≈7.63A, and another ∅17mm one (with swapped sense resistor for 5A, R010 + R050 + R200) was delivering 4.75 - 4.8A according to my precision PSU's amperimeter. In essence, 95% of rated maximum values.
The latter is paired with an CSLNM1.TG (1mm²) and I am happy with it.
BobbyMK if you want to push that a little bit more the math is easy. V = I × R = 4.57A × 10mΩ = 45.7mV sense. Stack an R100 on top of the stock R010 and you should get 10% extra maximum current, 5.027A.
Yes but 6A is perfect for the 4040 CULNM1 ;)
Stupid question, but is that just the same led on a bigger die?
  1. No such thing (edit: "no such thing as a stupid question" is what I meant here, I re-read this later and decided to clarify)
  2. According to Led4Power earlier in the thread, essentially yes. There may be slight binning differences (flux and/or Vf) between them, or at least between the batches he got.
  3. Bonus points: Boost HX is just the 2mm2 white flat, on the larger die.
Thanks for your reply, maybe i should have asked earlier, not after ordering :person_facepalming:
That 4040 CULNM might be just what i was searching for
