HKJ, whatβs your favourite charger in 2019? I would like to test mAh, charge 2/4 cell, display.
I have single cell tp4056 charger, 4 wire battery holder, skyrc b6 mini, zb206 battery tester, but all these can charge/test only one cell. I am looking for a decent charger in the price range of 20-30usd.
I have only published 7 charger reviews in 2019 and only two of them are 4 slot with mAh display and only one of these has adjustable current, that is the Nitecore UM4.
If you want to discharge batteries to measure them, the Lii-500 and BT-C3100 are still good cheap chargers.
You can also check my analyzer list: Round cell charger index (Analyzer)
500S is planned, but the first one I got died during the first charge and I have not received another one yet.
I do not have any plans for the Miboxer.
I have been trying to find a NiMh D cell smart charger. Chargers that will take 4 D cells for charging seem to be fairly rare. I have a couple of obsolete units made for NiCad; so no good.
I bought a bunch of D cell NiMh cells. I bought a couple of chargers from Soshine (the battery manufacturer). They charge NiMh, but have really stupid interface and no detectable (to me) smart properties. When charging they have little barometers (they look like barrels). They constantly have bars running rapidly up and down for each battery. Annoying and mostly information free. You could try interpreting state of charge from the little bars, but with any real information. It is on or off.
There are no actual values anywhere. And the batteries get quite hot toward the end. I am not sure they even stop charging when the little barrels are full. And if you are just standing in front of the charger you can not even see what the barrels are doing. You have to bend over to see.
This is the best I could find.
Can you (or anyone) point out a decent smart D cell charger that actually has controls and useful information. Preferably able to do 4 cells at a time.
Something like this and connected to the Opus (for example) BT-C3100 will I believe work, though I have tried it yet.
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
On the other hand, I have in the house a Xtar 2-bay charger that can handle 2xD cells, I canβt remember the model, Iβll check it later today when Iβm home.
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ-
I have not found a smart charger that appears to have enough space to insert 2 or preferably 4 D cells. That was why I got the Soshine charger.
Right now I am sitting here listening to the house smoke alarms. Hoping that they eventually get tired of the whole thing. It has been running for more than an hour so far. No way to turn them off. AC powered, but with lithium batteries. All daisy chained.
My best guess is that a Plant from Hell has emitted enough extremely powerful perfume in a room to poison the sensors. I moved it away from sensors. Nada so far.
I need to readdress my smoke detector system. It really needs to be able to be muted.
No one actually will care about my smoke alarms. I just rambled on while sitting here with an unused keyboard. And thinking about trying to get some sleep.
It will do 8x AAA>D, though I think itβs not such a good match for AAA. Expensive, does not do βtricksβ, but simply works. Been using one primarily for AA, C, and D for over a decade. I used to use it a LOT for D cells when my wife and I were diving with 4xD lights, so I needed to do 8 cells at a time every week. I still use it routinely. The only thing that ever happened is one bay got so it would not make contact with AA. The bay still worked for C and D. Thomas Distributing replaced it under warranty, and it was several years old.
Hereβs an old review from CPF by [Silverfox]. He tested a lot of chargers and this one came out as one of the best.
