In it’s simplest form light is just another form of heat/radiation. Whether it’s led, halogen, fluro, hid or whatever, they all produce heat. The more light the more heat.
I like Relampago’s analogy (nitrous). Turbo is for short bursts only.
Some manufacturers like to claim highest lumens possible but, of course, it’s not practical for the average muggle.
Barry, I think I have a simple yet sophisticated solution for customers who do not like hot flashlights without driving away your loyal fans and enthusiasts who prefer maximum power and output at all costs. This hint is meant for any „non-Andúril“ or „non-NarsilM“ flashlight with a simplified UI by Sofirn:
Just have a look onto my suggestions I posted here:
Please remove timer-triggered stepdowns from future drivers/flashlights. I do not see any reason to have both thermal and timed stepdowns at the same time.
Please allow a user defined choice of ATR thresholds (e.g. 45°C, 55°C, 65°C) just like HaikeLite did with their SC26
Thermal protection setting can be accessed by 10xclicks:
The light flashes once => turn it off to select 45 degree step-down temperature
The light flashes twice => turn it off to select 55 degree step-down temperature
The light flashed 3 times => turn it off to select 65 degree step-down temperature
Eventually, Sofirn could use 45°C as the default setting that will allow a safe and comfortable usage while flashoholics, experts, evangelists and enthusiasts can raise the threshold to a higher value they deem more reasonable, maxing out the full potential of Sofirn's powerhouse flashlights like SP70, Q8 and SP36. There will not be any trade off for customers who prefer a simpler UI than Andúril or NarsilM as they still get the chance to push their flashlights (and skin ) to their very limits.
About the warning sign...
Very good idea! I could help Sofirn to integrate this in future manuals (English and German). However, there already is a part („Caution....“) included that warns customers about excessive heat when using the light on high level modes.
I like to think aluminum & copper metal flashlight acting like headsink for led emitter. High thermal conductivity of Aluminum ‘237 W/(m·K)’ & Copper ‘401 W/(m·K)’ allow it to distribute heat really fast compare to lower thermal conductivity materials such as cast iron ‘52 W/(m·K)’, titanium ‘21.9 W/(m·K)’, stainless steel ‘14.3 W/(m·K)’ & PVC Plastic ‘0.19 W/(m·K)’. It reason why both aluminum & Copper used in cookware base of pans, heatsink & heat pipe, etc.
yes the problem is like 60% or more of emitters is produced heat, rest is lumens…. if the emitter didnt produce any heat it would be wonders…. many think its a flaw when a light gets very hot quick but that is the price we have to pay sadly…
If they don’t understand it the first time you explain it, tell them to turn on a (incandescent) 100 watt light bulb, and then lick it after a few minutes.
At the very least, they won’t be able to verbally complain to you anymore.
FW3A step 4 draws 561 mA and generates 177 lm pluss heat. Turbo draws 12A. If the Leds were as effective as in step 4 the flashlight would generate 3800 lm, pluss propositional amount of heat as in step 4. For turbo you can then add 1000 lm extra light energy lost as heat energy.
“This flashlight has the same power as a household lightbulb. Please remember that it will get very hot at high power, just like the lightbulb. For your safety, we have designed this flashlight to reduce power after 3 minutes at high power.”
(You can write “on turbo” instead of “at high power” if you prefer.)
Don’t ask me how to make people actually read the warning, though
No offense, but I don’t like the idea of giving Sofirn suggestions about more flashlights with timed stepdowns. A timed stepdown is the worst solution both for muggles and enthusiasts. Repetitive activation of turbo will still heat up the flashlight beyond its designated threshold unless a thermal controller is in place, too. But once you have a thermal controller (like „ATR“ called by Sofirn) in place you don’t need to have both timed and thermal stepdowns. That’s why I suggested to Barry to implement 3-4 user-selectable thermal thresholds for stepdown. Sofirn could sell their lights with a factory default of 45-50°C and put a big warning sign as well as some instructions into their manuals how to raise the threshold by hidden settings in the UI.
Anyway, here is what I wrote a friend on the same issue:
Turbo is per definition only for a short time useable.
Turbo means you can’t sustain this level of output forever.
Like a 50m sprint on full pace or nitroglycerin injection in a motor. If kept for longer you overheat or the motor dies.
In todays flashlight it is normally one level below high where you can use it constantly. With a normal 18650 light that is 500 to 1000 lumen, depending how it is built.
LEDs produce heat as a incandescent light bulb, but only on a lower rate, but they do.
How hot the light gets depends on the output (the brightness setting) and how good cooling is (mostly the surface area of the lamp)
I know lamps with 5 seconds turbo time and some with 15 minutes.
3 minutes are quite long to light something up.
If you want a high output for long time you must buy big lights, e.g. the size of an old D-cell MagLigte
I would prefer a light with ATR-style thermal regulation too, as long as I can choose the temperature, change back to a timed stepdown, or even turn ATR and stepdowns off altogether. There are people who actually like an abrupt stepdown as a useful reminder to think about what their light is doing.
My favourite lights have no stepdown or ATR whatsoever, because I know how to use them safely.
My text was just an example. Sofirn can certainly change that last sentence to something like:
“For your safety, we have designed this flashlight with Automatic Thermal Regulation (ATR). This will reduce power if the flashlight gets dangerously hot. See page 4 of the user manual for instructions on configuring ATR.”
That way, people who don’t read the warnings can’t learn how to endanger themselves. Poetic justice
